Super Moderator
Rocker arm bushing check and replace?
Since I'm rebuilding my motor, is it prudent to replace rocker arm bushings? (Although it appears that the whole rocker arm must be replaced...
How do you check them for wear? Thanks
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 11-13-2002 at 08:54 AM.. |
Senior Member
I think you can just replace the bushings, but if they are worn, then the shafts are worn, too. Inspect the shafts, you'll see the wear. I did not put new bushings in. I just turned the shafts upside down.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Senior Member
Chris,
When I found out just how reasonable the cost was to re & re my motor's rockers and shafts, I sent 'em to CE. Send an e-mail to Walt at CE asking for details. I'm finding out this is the first class outfit just like everybody said it was.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Competition Engineering = Home Run
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
