Super Moderator
cstreit's Avatar
Rocker arm bushing check and replace?
Since I'm rebuilding my motor, is it prudent to replace rocker arm bushings? (Although it appears that the whole rocker arm must be replaced...
How do you check them for wear?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-13-2002, 08:52 AM
Senior Member
Superman's Avatar
I think you can just replace the bushings, but if they are worn, then the shafts are worn, too. Inspect the shafts, you'll see the wear. I did not put new bushings in. I just turned the shafts upside down.
Mocha 1978 911SC. "Coco"
Old 11-13-2002, 09:51 AM
Senior Member
Doug Zielke's Avatar
Chris,
When I found out just how reasonable the cost was to re & re my motor's rockers and shafts, I sent 'em to CE. Send an e-mail to Walt at CE asking for details. I'm finding out this is the first class outfit just like everybody said it was.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 11-13-2002, 04:20 PM
Cool
Competition Engineering = Home Run
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-13-2002, 04:43 PM
