aircooled addict
jimbeaux911's Avatar
CIS tester reccomendation
can anyone reccomend a CIS tester that they have used and think is a good one
someday I will actually get to drive a 911
Old 07-12-2015, 06:19 PM
Charles Freeborn's Avatar
If you mean fuel pressure tester, the Harbor Freight one is adequate for occasional use. Professional grade units are out there, but not cheap. Snap on, etc likely has sets, or build your own with only the fittings you need and a gauge from McMaster.
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 07-12-2015, 07:30 PM
I just had had major issues with the HF gauge set up. The 4 small shrader valves in the lines are very restrictive and make the readings inconsistent, I know some people have had success with the HF gauge but the one I used did not work well. When I removed the valves it still did not give accurate control or residual readings. I bought the same one that pelican sells (S&G Tool Aide around $100) and it works much better. I wish the bleed off valve had a drain tube. But if you rap a rag around it when bleeding pressure it keeps the mess to a minimum.
1983 SC Targa, 1973 911
FFR Cobra
1941 Dodge Truck (restomod)
1955 Plymouth Wagon 2dr
1973 Porsche 914
Old 07-13-2015, 06:31 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
Same experience as pmead; avoid the HF setup even though it has lots of nice pieces. The one our host sells works well, and they will stand behind it.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 07-13-2015, 04:36 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Not sure if I bought from PP or another source but it was about a buck and a quarter seven years ago. Works every time, all the time. Simple set. Not universal.
I can't discount the HF setup as I do not own it. However, I do a lot of "basic" AC work and I have Robinaire gauges and a couple of HF gauge sets. Honestly, and I mean for real, I don't trust the HF gauges after a year of use.
1981 911SC Targa
Old 07-13-2015, 07:49 PM
Coram Deo
RDM's Avatar
If you want the HF set, I'll sell you mine at a discount.... You've been warned, but maybe you can work out their problems.
Dru
Old 07-14-2015, 02:48 AM
