evan9eleven's Avatar
Fire extinguisher install. Some assembly (and welding) required.
So its good I can sorta TIG weld. I was thinking I could just make my own stainless fire extinguisher seat mount, but hey, why re-invent the wheel? So I bought a Brey-Krause mount from our host and went looking for a nice quick-release that would work with my large extingusiher bottle. I ended up buying a slick QR from Scott Drake (purchased through Amazon, Pelican should really carry these!)
I could have just bolted the drake mount to the floor or to the tunnel but decided I had to have the extinguisher up front and on the passenger seat. Problem is the drake mount is longer then the mounting plate on the BK mount, so I decided to weld a plate to it so I could mount the QR:
So far so good, but since the BK bar is made to work with small-bottle extinguishers, its angled up from the floor. So my passenger would have an extinguisher touching the backside of her knees all the time. Not popular with the wife, so I cut up the BK mount and rotated it downwards, then welded it back up.
Used some beefy stainless clamps to hold the bottle and bingo! Nice and tidy, no passenger interference, seat adjusts as normal. Pull the red knob and the bottle is free in a second.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 07-17-2015, 11:53 AM
Driver, not Mechanic
Nice work.
Since I can't weld, I just bought a regular Rennline from our host. (Or was it Rennline.com directly when they gave out a discount code?)
Old 07-17-2015, 12:01 PM
nice job. having used rennline and BK in other cars (I have a BK quick release on my RS with a roll bar mount)...
Which is the best mount that won't interfere with the seat movement, works with power seats, and will hold a 2.5lb bottle for a g series?
Old 07-17-2015, 04:24 PM
I think the BK would be fine by itself with a 2.5lb bottle. They make a version for power seats. The Rennline and others also look nice but the BK suited my needs (even though I did have to mod it due to my chosen bottle and QR.)
2004 Boxster S
Old 07-18-2015, 11:23 AM
El Duderino
tirwin's Avatar
Evan,
Nice work!!!
I have been looking for a solution to the same problem. I have the same BK bar that I used with the original seats. Since I put the Corbeaus in the car the BK won't work without some modification. And when I was using the BK mount the passengers complained about it.
Now you've got me thinking about different options.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 07-18-2015, 11:33 AM
Originally Posted by tirwin View Post
Evan,
Nice work!!!
Thanks Tim! I guess its time for you to bust out the welder! I should offer up a disclaimer which is that the missus hasn't been in the car since I finished mounting everything. So we'll see if I acheive some level of wife approval. I suppose since you had an extinguisher mounted before you've already fielded the wifey's questions about how likely it might be for the car to catch fire...
The BK bar really does angle upwards quite a bit. I figured you guys with the smaller extingushers would have no issues with passenger leg clearance but maybe not? A little cut-rotate-weld work made all the difference, now the bottle sits maybe an inch off the floor. I made sharpie marks on the parts I cut so I would have a reference point, and probably only moved the marks 5 -7mm apart and rewelded. That was enough to effect a big change out on the bottle end. I could have gone a step further and shortened the bar too so the bottle would sit closer to the seat but decided this was OK for now.
I really like the Drake mount, and its dished on the backside for mounting on a harness bar or rollcage, but mounts fine to flat surfaces too. Since I just installed a Wevo shifter I guess mounting it to the tunnel would have been easy, but probably would have made the passenger footwell a bit awkward and cramped.
2004 Boxster S
Old 07-18-2015, 12:21 PM
Quick update 3 years out: been on several drives including a 1000-mile road trip this summer with the wife as a passenger. Not one complaint about the fire extinguisher.
2004 Boxster S
Old 12-13-2018, 12:40 PM
I'm good with tools.
AG81's Avatar
Evan,
I recommended this mount to a fellow member today. I have been using them for a few years. Really like the quick release and it seems to not rattle about like other manufacturer's models.
Well done.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 12-13-2018, 03:04 PM
Red Line Service
Marc Bixen's Avatar
Why didn't you just buy am Element fire extinguisher ( www.elementfire.com ) and throw it in the glove box? No problem for the wife.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 12-13-2018, 05:38 PM
Bill Douglas's Avatar
Old 12-13-2018, 06:23 PM
Red Line Service
Marc Bixen's Avatar
Hey Bill, thanks for being in agreement, thanks for the complement...
By the way evan9eleven, beautiful fab work!
Old 12-14-2018, 07:24 AM
Kraftwerk's Avatar
Better if your fire extinguisher is solid mounted not in the flimsy glove box.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 12-14-2018, 07:32 AM
Each to his own. My FX bottle is probably twice the size of the glovebox model and in case of fire I'll be really happy to have the capacity. Nice to have it securely fastened as well.
As I said, no complaints by the wife, so that test is passed. Not that I was really that concerned.
Anyway, thanks for the compliment, I'm happy with the result!
2004 Boxster S
Old 12-14-2018, 08:27 AM
Old BK, a little steel stock, out of the way, pretty easy to grab
82 SC Twin Plug 3.2 SS ,46 PMO
Old 12-14-2018, 02:55 PM
Just watched Leno's garage demo on this and ordered a couple for Christmas presents. A better and (much) smaller extinguisher. Thanks for the tip!
Old 12-14-2018, 08:32 PM
Burnin' Rubber
Koizumi's Avatar
Old 12-15-2018, 04:40 PM
