RETIRED
Joe Bob's Avatar
Labor rate to replace one CV boot?
915 axle, already pulled.....just need the CV R/R, boot installed and greased up. One hour shop rate for labor? I don't have the tools I used to.....please, no dickhead replies, I've had a rough day.
2012 ML350 3.0 Turbo Diesel
Old 07-18-2015, 04:23 PM
VW_NUTT's Avatar
Come to my house with some Guinness and I will do it for FREE.
1984 Carrera
1985 Vanagon Westfalia
2009 Audi A3
2015 VW Jetta
2016 Sprinter
Old 07-18-2015, 04:34 PM
RETIRED
Joe Bob's Avatar
11 minutes, not a record but close.....
Old 07-18-2015, 04:38 PM
Fleabit peanut monkey
Bob Kontak's Avatar
11 minutes? Your girlfriend did it then.
1981 911SC Targa
Old 07-18-2015, 05:12 PM
RETIRED
Joe Bob's Avatar
So what is the book rate? It's been so long since I had to pay someone except for your Momma.....
Old 07-18-2015, 05:14 PM
Banned
^^^ The one and only queen of the 50-cent charge!
Old 07-18-2015, 05:21 PM
Bob Kontak's Avatar
Three minutes if you're slow it says.
1981 911SC Targa
Old 07-18-2015, 05:23 PM
Bob Kontak's Avatar
Nuttin' under a buck anymore. Dad laid down the law.
1981 911SC Targa
Old 07-18-2015, 05:27 PM
RETIRED
Joe Bob's Avatar
Ok, which one is yer Momz (shut up Sid.....)?
Old 07-18-2015, 05:32 PM
Bob Kontak's Avatar
I was scarfin' a burger when I saw this.
Nice. Real nice.
1981 911SC Targa
Old 07-18-2015, 05:35 PM
1 hour is a nice round number. $100-$125.
Good luck.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-18-2015, 06:11 PM
Banned
So is that money well spent, Bob?!?!
Your first for the day . . . or your fifth?!?!
Old 07-18-2015, 06:17 PM
DanielDudley's Avatar
Take the parts to the local brake shop. Get rid of the Porsche box.
Old 07-18-2015, 06:20 PM
Fixer's Avatar
Bob,
There are no "special" tools required to do this and if one boot is bad your likely to have to do the other side soon.
Why not just buy what is needed and save the hassle. then you own the tools.
If you have the ability to remove the axle i can't see why you need help with the boot.
It's a 15 minute job.
Maybe this is a joke i'm new around here.
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 07-18-2015, 06:32 PM
Formerly known as Syzygy
Canada Kev's Avatar
Prolly just needs the pliers for the band.
Kevin
Old 07-18-2015, 06:49 PM
SCadaddle's Avatar
Zip ties!
Old 07-18-2015, 07:44 PM
RETIRED
Joe Bob's Avatar
The boot was cut when the heater hose let go and the wire sprung loose and cut the boot. The axles have less 10K on them and were bought as a set from Eric at PMB Performance. They have been sitting in sealed bags since replacement with another set I had on the shelf. Long story....needed them NOW and fixing wasn't an option. I used to break a lot of things when active in DE and AX, so a lot of spares.
Fixing is now an option. Don't they need the CVs pressed off? Maybe I should pull out the Bentley. CV grease and tranny oil has to be the worst job I know of.....that's the reason for this thread.
Not being a pansy like Bob K but I get ill from the smell of the tranny grease/oil.
Old 07-18-2015, 08:21 PM
Mike80911's Avatar
The CVs are held on by a snap ring after you clean away all of the grease you will see it. It is a very easy job to do.
89 930 Cab Black
11 Cayenne
Old 07-18-2015, 08:38 PM
El Duderino
tirwin's Avatar
It's a messy job, I did it a couple of months ago. Mineral spirits or turpentine in a tall bucket to clean them up. Take the snap ring off. They can be frustrating to get aligned correctly. Pay attention to the alignment of the inner and outer pieces. The fat curve aligns to the thin curve and vice-versa. I used Swepco CV grease when I put them back together.
Remember that the newer boots have the thinner flange and the bolt sizes are different. Not an issue if you already had the newer style.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 07-18-2015, 08:51 PM
RETIRED
Joe Bob's Avatar
Crud.....just found my Bentley under ten boxes of junk.....OK, my brain cells are realigned. Still a nasty job. I'll wear my HEPA filter mask and gloves. Order the boot thru Pelican via Eric.
Thanks guys....
Old 07-18-2015, 08:54 PM
