88 Carrera, Guards Red
Stock evaporator performance ?
I have seen some really amazing numbers (temperatures) from folks who have conducted various levels of upgrades to their AC Systems. What I would like to know, is what is the best I can expect if regardless of whatever else I upgrade, I stay with the stock evaporator? Or maybe stay with the stock evap and put in a fresh TXV ??
Fleabit peanut monkey
This is my experience base. A single point of reference.
Garage queen 89 930 and my 81. My pal and I worked our natural behinds off flushing, changing o-rings (on his - I had tapered interfaces), re-oiling, new receiver driers and TVX valves. I think he installed the pro-cooler type R/D. Both refreshed with R-12 as I got lucky on ebay and snagged a sealed 30lb. tank of DuPont for a fair price. Here is the rub. Both of our front condenser fans did not work. Both 55F vent temps in around 85-ish F temps. Tolerable but not chilling. Guessing the operable fans would have stripped 5F ? His relay was bad (tall one up by the front left light) and my fan turns hard. That's all I got for you.
1981 911SC Targa Last edited by Bob Kontak; 07-16-2015 at 04:41 PM.. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Evaporator.
Also, re-tuned the temp switch for a 10f hysteresis from the factory 6f setting. This has reduced evaporator freeze-up in our Hi humidity environment which has been an ongoing concern. The rest of the system is factory stock. If you choose to replace your evaporator, it should be equipped with the already installed appropriate TXV. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 07-17-2015 at 09:03 AM.. |
First, you need integrity and reliability. No leaks, the system works when you need it.
This means, if you don't have them, barrier hoses, new o-rings, drier, low high pressure switch. If you have a 86-89 year, the evaporator is prone to leaking because they tried to bond a copper manifold to aluminum tubes and the bond fails over time. Depending upon the mileage on your compressor, as a minimum a seal kit if the internals are good or a new denso. Second, is performance upgrades. Besides a better evaporator, you need more condenser performance or function. For an Atlanta climate, you need a lot. The evaporator pulls the heat out the car and the condenser releases it outside. A rear fender condenser would help; maybe 2 or at least 1 and upgrade your front condenser You can read about what others experienced with upgrades in the forums; in terms of Griffiths AC products, here: Customer Comments, Porsche 911 and 930 Air Conditioning Upgrades |
I drove my 85 911 for over 11 years with just the stock system. It was not much fun in the dead of summer.
![]() I finally upgraded my system 9 years ago to a dual Kuehl system and added two condensers and all new hoses and vents. This is a picture I took of my old evaporator. No doubt that was big part of my problem. The drain hole was partially plugged and the entire box was filthy. Just pulling that old evaporator out and cleaning would have helped but replacing it was the logical thing to do. As Charlie mentioned, more condenser area is the big step up. You can peek at the bottom of your evaporator from the passenger compartment. Pull out the carpet and floorboard and the resistor pack. It is pretty easy to take a look and see if it is a gross as mine was.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
The FIRST thing to do on your way to the most comforting A/C is TINT the windows to the greatest level that is legal in your state. SECOND, find a way to upgrade the condensing efficiency such that the system provides an adequate supply of liquid refrigerant to the TXV in the worse case conditions. For some of us, that meant simply adding cooling fans to the rear lid condensing such that it could remain productive when the cooling flow provided by the engine fan was not adequate. For others, in the extreme, it seemed to require upgraded front lip condensers, dual rear fender condensers, along with more efficient evaporators and evaporator blowers. Care must be taken here since at least one person with the FULL upgrade "boat" freely admits that his A/C comfort level involves sitting in a sub-freezing air stream for hour upon hour. But I digress.. If, for whatever reason, adding fans to the rear lid condenser doesn't float your boat, then the next best answer is a condenser/fan combination mounted in the front of the driver's side rear fender. You can power the fan via a relay activated by the power to the compressor clutch, as most owners seem to do, or you can use the third element of a trinary pressure switch. You will need to add a pressure switch regardless of what else, whatever, you choose to do, upgrade, otherwise. There is, literally, no additional cost for a trinary switch vs a binary switch. Using the trinary switch to control any cooling fan(s) would avoid running the fan(s) when the engine RPM provides a satisfactory level of cooling airflow. And keep in mind that high side pressure doesn't instantly abate with the compressor cutoff. Trinary powered fans would continue to cool the high side until the pressure declines below a set level. Once you get to the point that liquid refrigerant is available to the TXV in the worse case conditions then it is a quite simple matter to determine if the evaporator/blower combination is efficient enough to "BURN" all the "FUEL" flowing out of the TXV with a FULL heat load. Last edited by wwest; 07-17-2015 at 08:47 AM.. |
Banned
Added efficiency in ANY part of the heat exchange system leads to better performance. Including the cabin portion of the system. Your continued assertion that the choke point of the system is the condensers is false. It has been from the beginning and continues to be false at every repeat. The choke point for this system is the evaporator. It is simply too inefficient to cool the cabin adequately. In fact, upgrading the condensing capacity will have very little effect on cabin temps absent modifications to the evaporator system. The proof of this is that suction line devices work at all. And they do work, from reports here. If the evaporator was 100% efficient, the suction line devices would have nothing to do. This means there is excess condensing capacity in the stock system. Straight physics, with evidence. Yet another assertion of your proven false. Will you please stop posting your incorrect and misleadsing drivel? Thank you |
OK, I think this thread can now end before we begin the constant back and forth that tends to destroy most AC threads. I am a new owner living in NC so the AC threads have been interesting reading...to a point. I need to improve my original AC in the coming year and I have excellent ideas now and have developed a plan to move forward. To continue to beat the dead horse is pretty pointless and I think the OP's question has been answered.
Looks pretty bad, huh..??
![]() But there is no way to know if, or not, the evaporator was doing a perfectly adequate job "as is". The evaporator in my 1988 Carrera, <100,000 miles, might well look this bad, or possibly even worse. But the vent temperature and the suction pressure indicate that my evaporator is "Burning" all the "fuel" a wide open TXV, with a adequate supply of liquid refrigerant(***), can provide. *** 92dF OAT, engine idling (800 RPM), doors wide open, max cooling and blower. But to be perfectly fair my A/C compressor thermostatic control switch has been calibrated such the evaporator core will not decline to the sub-freezing level. |
Banned
I will repeat: the stock system choke point is at the evaporator. This is so because suction line systems attached to the stock system are reported to work. This would not be so if the evaporator was able to transfer all the energy that the compressor generated through the condensers. Upgrading the evaporator/evap blower will help the stock system perform better. |
And you're supposed to be the most intelligent one of Charlie's disciples....
And then we have this thread. Jump to post 93...
Retroair complete system in my non a/c car Yes, upgraded evaporator/blower, but a 930 with a sub-standard rear lid condenser/fan capable of supplying adequate refrigerant flow to the TXV? Reflective condenser surface rejecting radiant heat from the engine/exhaust/catalyst? If not, then what, how? EDIT: On second thought... OP has restricted inlet flow to the evaporator plenum, so overall flow volume may be more toward factory than otherwise. Still, IMPRESSIVE results. Last edited by wwest; 07-17-2015 at 10:15 AM.. |
Banned
If I improve efficiency on every component, then overall I can still have a bottleneck in the same location, but that the capacity of the entire system is much higher. Your analytical thinking skills are poor. And Charlie and I have not disagreed on how poor the stock evap is. |
Banned
Oh, make sure you don't just compare those two numbers. The perfect radiant (or absorptive) black body has an emissivity of 1.00. The difference between aluminum and polished aluminum is REALLY small in comparison to the total possible emissivity, which is in the numerator of the calculation. LOL. |
But what about "incoming" radiant effects, white, black, silver, or even a chrome or fully mirrored surface?? And the answer is: http://littleshop.physics.colostate.edu/activities/atmos1/ColorAndCooling.pdf |
Banned
And yes, even I will agree that most any of the modern aftermarket will out perform the factory evaporator provided the supply of refrigerant is adequate in both cases. By the by, what is the BTU rating of the factory TXV vs Charlie's. |
Banned
In refuting what you claim, it is the point, exactly. When you attempt to change the subject, or switch the discussion around, or redirect it, you are abusing the privilege of posting here. Making wild assertions you cannot prove, making promises you will not keep, all of this makes your posting worthless, and you cheapen every thread in which you participate. You are not helping anyone improve their AC.
If you have not removed your evaporator assembly, take a flash light and mirror and look at the under side of the radiator through the hole under the passenger footboard. Obviously after removing the electrical equipment in the hole. You may find what you see in the picture above.
Or not..............another thread high jacked and destroyed.
