Turn signals and hazard not working on 76
Hi guys,
I have replaced the relay behind the oil guage and checked the fused - not that. No melted sockets either. Any idea what to check next? Thanks, Christian |
Take the fuses out and clean them and replace. Start checking for power and continuity on each wire in the system. http://members.rennlist.org/911pcars/WiringDiag.htm Go to this link to find a wiring diagram for your 76. I emailed a copy to Staples and had it blown up and laminated
One easy thing to check is the black connectors that plug into the firewall just above your feet to ensure they are seated well. Sometime the one that goes to the turn signal comes unplugged.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Thanks guys,
Flint, you nailed it. Blink blink blink....thank you so much! |
No problem. Glad to help.
Thread Tools | |
Rate This Thread | |
