Another Clutch Question - Bent my pedal
I was adjusting the clutch and made the mistake of pushing in the clutch pedal from outside the car (not sitting in the seat). Next thing I notice, the clutch pedal bent in towards the brake.
Question: Should I order a new pedal or straighten out the old. My concern is that the metal is fatigued and will continue to bend. I have previously rebuild the whole pedal assembly so this is kind of a drag to have take that all apart again but I will if I have to. Any advice? |
The Bavarian
I assume that the pedal hasn't been bend too much (in degrees), thus I think it hasn't been weakened substantially. Simply bend it back where it belongs.
- Manfred
'80 911 SC Targa black/black |
Member 911 Anonymous
+1 just bend it back if not too bent inward.
post a pic. My brake pedal was tweaked a bit to the left from PO with an elephant foot. I just straightened her right out.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Not to thread-jack, but Jim - yours is the case I was trying to recall/search for recently. There is another thread here with a similar condition, and I couldn't find your(?) example. I will try again now.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
