89 Fuse Question - Yes I searched!
Ok, I have a diagram and such for the main frunk fuse box + the one in the engine compartment.
I also know of and see the fuse for the condenser fan.
2 questions:
--I seem to have an inline fuse (screw holder type glass fuse) near the fuse box, it looks factory wired, any idea what this is?
--what other fuses are in the car and where are they?
I'm in the process of going through all these to ensure they are the right factory rating, replacing some, and cleaning the contacts.
Thanks!
Old 07-30-2015, 11:28 AM
jdbunda's Avatar
Picture needed.
John
1972 911T 3.0L Coupe
1986 Carrera Targa
1989 BMW M3
2007 328iT
Old 07-30-2015, 11:58 AM
Check the wiring diagram. If you don't have one you should get one.
Old 07-30-2015, 12:01 PM
Originally Posted by jdbunda View Post
Picture needed.
Soon. Car is getting aligned today.
Source for one that is accurate and specific to the '89?
I have the fuse box diagram and a diagram of "electrical component locations" There is reference to "Additional fuses" - 16 Radio - In luggage compt
This diagram doesn't describe the fuse on the condenser fan though.
Old 07-30-2015, 12:40 PM
Project Addicted
I had an 89 Targa and had taken some pics of the fuse panel. I don't recall any inline fuses... I was cleaning it up so some fuses are missing. If I still had the car, I would be doing the upgrade to the fuse system described in a post last week. Cheap and a much better set up.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 07-30-2015, 01:18 PM
There is no fuse like that on an 89. Someone along the line added it
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 07-30-2015, 01:26 PM
Thank you for this and the PIC. hmmm!!! I know there was a cell phone in-car setup at some point, could have been that maybe.
I'll post a pic.
Are there any other in-line fuses in the car I should be aware of?
Old 07-30-2015, 01:42 PM
wwest's Avatar
The fuel pump fuse holder often overheats loses its "springiness" and must be replaced. An inline fuseholder is the easy and quick solution.
Old 07-30-2015, 01:47 PM
Project Addicted
This thread is what you should be doing with your fuse block while figuring out the rest of the mess.
A phone, alarm, who knkow what the PO's did over time.....
Fuse Panel Swap - ATC Done under $35 total
Jon
1966 912
1986 944
Old 07-30-2015, 03:11 PM
Recreational User
porschenut's Avatar
I believe that is your license plate light fuse. You can verify by removing the fuse from the holder and see if your license plate lights still work. Both of my '86 cars and my '88 car have that inline fuse.
Old 07-30-2015, 05:42 PM
This is the fuse. Haven't tested to see what it is. But pretty sure this is factory.
Any other inline or surprises fuses on this thing?
Old 08-01-2015, 10:32 AM
tholyoak's Avatar
It's the factory fuse holder for the optional amp that sits on the floor under the passenger seat
1989 911 Targa
Old 08-01-2015, 03:55 PM
Thank you! Yes my car has the Reno and hifi amp. Both still work well.
Any other in lines in the car? That aren't documented?
Old 08-01-2015, 05:45 PM
