'74 Flappy Heater Box Stuck Open
Last year, I accidentally pulled the defrost instead of the throttle lever, and the box is stuck open. It sends hot air to my feet and lower legs and makes driving for more than 30 minutes hell on feet. Unfortunately, I also forgot how to fix this..
![]() I'm not looking to replace them yet, just want to close the valve or flappy thing shut to stop the molten air from getting in the cabin. How exactly do I do this? Where is the valve located in the rear? And is there one or two?
Karl '80 931-Dolomite Gray -> Monaco Blau '74 911-Guards Red |
Member 911 Anonymous
Yes, it is under the car in the rear next to wheel wells. Most likely Orange flex heater tubes going into it.
You need to raise the car safely to gain access. Get some penetrating lube and spray the pivot points to break it loose and close it manually if wire is snapped. There are two. Flaps will appear to be close, which mean open to the heat exchangers. You want to OPEN the vents so it will close off the tube going towards your cab.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Karl--call me if you need help with this.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
