Some added details. this was the first charge attempt after all new hoses and new evap went in. All three condensers had been thoroughly flushed and been baking in the sun for days and periodically i'd blow air through them to make sure they were dry. I connected the r/d in about 3-4 minutes after breaking the seal It was the last thing I did before hooking up the vacuum pump. The pressurized gas is a good idea, just not sure where to get it and how to do it. I'll do search on that.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
another option (and the one I will be using) is a CO2 tank. I have a kegerator, so I have 2 CO2 tanks around, and getting one filled costs about $12. A 10 pound tank at 500psi will last a long time backfilling automotive A/C systems... You might find a 5 pound tank for $30-40 used if you check craigslist. Now, backfilling is probably more work that needed, but it is an option. If you're dryer was clean (and it sounds like that's the case) then maybe you just need to pump more. Try a 3 hour pull, let it sit overnight, then another 3 hour pull.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Adding a can of r134 to circulate around is a good idea I will try that, thanks!
And, if you ever read some of Porsche's factory manual charging instructions their machine flushed the system with refrigerant prior to charging. Ignore wwest |
1) Tank 2) Regulator. 1 or 2 gauge, around $40-50 new, much less used The output of the regulator is a standard thread shared by, well, looks like everything. So, unscrew the barb connector that comes with beer regulators, go to harbor fright, buy an air tool accessory kit, and screw the standardized threaded adapter into the regulator. Magic, you have a standard air chuck QD on a 0-60psi regulator that you can carry around the garage. Toss your coil up airline on it and you can do all sorts of stuff. not enough to run air tools, but plenty for everything else. I picked up a used kegerator and used the cheap air tank and single gauge regulator that came with it, while buying a nice aluminum 10 pound tank and 2 gauge premium regulator to use with the beer.
El Duderino
I followed Charlie's instructions. Pulled a vacuum to 28.5 in Hg @ 1000 feet above sea level. No leaks. Put in a static charge from 30 lb R134a tank for 20 minutes. Evacuated and pulled vac for 2 hours. 30 minutes later, no significant leak. Charged the system to 258psi @ 95°F ambient temp in my garage. Initial charge done by weight to 36 oz. Fine tuned the charge by temp/pressures. Have a few more things to do before I can take it for a test drive, but I'm extremely pleased with the results so far. I can't wait to see how it performs on the road. Oh and as soon as the car was shut off the high side pressure started dropping. In summary, listen to Charlie. Ignore wwest.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. Last edited by tirwin; 08-09-2015 at 08:11 AM.. |
Banned
Bob, it looks like you had the "Five Stone Breakfast" today! |
El Duderino
As much as I like the added bonus of having a CO2 tank around for a kegerator, why wouldn't you just use a little R134a for this purpose?
Of course, if you're a Guinness man you need both CO2 and Nitrogen.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
So...my takeaway from all this is to get a kegerator...awesome! Nice IPA on tap would make all this work more fun.
Discseven's "final"....
High side still "fluctuating". Low refrigerant charge. Factory R12 = 48 Oz, R134a "recommended" =36 Oz. With Kuehl fender condenser/fan..... 40 Oz..? "Proper" charge, 40 Oz, idle vent temperature = driving? One would think with extra condenser/fan one would get better idle temperatures vs factory with 2 Spal fans. Post #6, near bottom My AC burns me up --- Summary of fix
Decided to try adding one can (12 oz) R134 and let that cycle through to see if it will help fully evacuate system. I noted the pressure for the record and was seeing 15/260 at around 2k RPM, at idle it was 40 on the low side with the high side rapidly fluctuating between 250-300. Air from vent was barely cook at all, which I guess should not be too big a surprise.
Not driving the car much not but may take it out later to run it some and then evacuate again tomorrow. Hopefully it will work better. One thing I noticed, which I'm pretty sure did not hear before, was a distinct "clackity" sound from the compressor when the engine returned to idle speed...maybe replace it before something more serious happens? Thanks
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten Last edited by 88911coupe; 08-09-2015 at 12:45 PM.. |
Only to accept, in the end, that the fluctuating high side gauge reading had to be accepted as being from another causative factor, unknown. Plus, it should be noted, a refrigerant charge level very close to half that widely recommended for r134a retrofits. |
"maybe replace it before something more serious happens..?" <12 Oz, 2000 RPM...how long? Quite possibly something serious just happened. I don't think there is anyone that would advise you to run the compressor with a KNOWN low refrigerant charge. |
Banned
I can't figure out how to find that thread statistics page that shows who has posted in this thread and how many times they've posted, but at a quick glance, it appears that the person with the most posts here is the the guy that does not do his own a/c system evacuation and charging - makes zero sense.
Added 6 oz ester oil to compressor after it had been thoroughly drained while cleaning condensers and installing new hoses.
Never fired one. |
Banned
Have you been drinking excessively?!?!?!
