I would rather be driving
jpnovak's Avatar
Help. Need 930 transmisison fastener torque value
Hi, reassembling a 930 transmission after new syncros and a few other wear item replacement.
Can someone tell me the torque value for the:
bearing retainer plate (is it the same as a 915?)
input shaft main nut
pinion shaft main nut
Old 08-16-2015, 09:43 AM
Plate 16-18ftlb
30mm MS collared nut 160-170ftlb
20mm MS collared nut 120-130 ftlb
24mm Pinion collared nut 180-190 ftlb
206 637 4071
Old 08-16-2015, 09:59 AM
jpnovak's Avatar
Thanks John.
I had 2 of 3 correct. I thought 110 for the 20mm nut.
Always good to verify. Now I can finish it all up.
Old 08-16-2015, 11:02 AM
