| I would rather be driving Join Date: Apr 2000 Location: Austin, TX
				Help.  Need 930 transmisison fastener torque value
			Hi, reassembling a 930 transmission after new syncros and a few other wear item replacement.  Can someone tell me the torque value for the: bearing retainer plate (is it the same as a 915?) input shaft main nut pinion shaft main nut Thanks
				__________________ Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks | ||
|  08-16-2015, 08:43 AM |
| Registered Join Date: Mar 2001 Location: Marysville Wa.
			Plate   16-18ftlb 30mm MS collared nut 160-170ftlb 20mm MS collared nut 120-130 ftlb 24mm Pinion collared nut 180-190 ftlb
				__________________ https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 | ||
|  08-16-2015, 08:59 AM |
			Thanks John.   I had 2 of 3 correct. I thought 110 for the 20mm nut. Always good to verify. Now I can finish it all up. | ||
|  08-16-2015, 10:02 AM |
