Installing 95 993 3.6 into 82sc
Came here to Pelican a long time ago. And always read all the posts regarding 3.6 swaps. And finally got mine. I bought the car in 2008 and never got to it. Family, Kid, dogs, another kid, life.
So i bought a 993 engine and want to install it. Have couple of questions. Wiring Harness Adapter - this i get Flywheel - Flywheel came with my motor, do i need to get specific one for 915 transmission Throttle Cable - this i get Single Pulley - this i don't understand. Does the fan on 993 has a clutch? I was planning to leave A/C Compressor and have a working A/C Power Steering Block Off - I also do not understand this. Is it some hydraulic thing that needs to be plugged? Cold Air Intake 3.0/3.2 Engine Tins 3.0/3.2 Pulley/Engine Console External Oil Cooler install. I have 2 oil coolers in the front bumper, can i just route the hose to them? Do i leave the oil tank on the side in the quarter panel as well? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
'77 Porsche 911 S Red/Cork Tan * Turbo Tail * 930 Steering Wheel* 17" Fuchs (r) * 3.2 * 915 * LSD * 930 Brakes * Elephant Racing Suspension * Turbo Tie Rods * Bilsteins Sports * Steve Wong Pre-Muff * B&B EXhaust * SW Chip on 4K DME PCA Last edited by axvel; 07-16-2015 at 11:05 AM.. |
The car was a stripped insurance sale when i got it.
'77 Porsche 911 S Red/Cork Tan * Turbo Tail * 930 Steering Wheel* 17" Fuchs (r) * 3.2 * 915 * LSD * 930 Brakes * Elephant Racing Suspension * Turbo Tie Rods * Bilsteins Sports * Steve Wong Pre-Muff * B&B EXhaust * SW Chip on 4K DME PCA |
Banned
The excitement builds! Good luck with the build keep us posted on how its going!
Will do, thanks!
don't worry about a cold air intake, there is a snorkle line addition to the stock air box intake that can be purchased but it is not at all necessary, the cooling fan keeps engine bay temps near ambient while it is running fast. most of us retain the 2nd engine mounted oil filter and run several variations on front cooling, for track use you need a ton of cooling and a large valance mount is a minimum, add one or two fender mounts for additional cooling, for street use a med/lrg valance mount or maybe 2 fender mounts is fine Most likely but not necessarily you will want to ditch the engine mounted cabin air fan and duct heat w/ an RS tube
Bill thank you for your input. Greatly appreciated.
From this list is there anything that i need to add to it, or something i can do without? ![]() ![]() Quote:
Your 3.6 looks very clean. Good luck with your build.
mind if I ask what the 3.6 ran you?
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html |
camshaft block off cover is needed the oil pressure sender from you SC might work, if not get the pressure sender, the 993 sender gives reading too high same w/oil pressure sender studs to mount the trans are needed oil feed adapter(993 version) is needed KEP clutch set is recommended the oil lines are needed unless you already changed the stock SC ones single belt fan drive is recommended the starter ring gear is needed secondary injection block off if deleting SAI, recommended for track use the catch can can be desireable wire harness conversion is needed
Looks like a nice project good luck!!
Looking good
Tony 91 964 c2 black/ Work in progress/Finally back on the road 85 EURO 930 Black slightly moded slowly reviving her 77 911tt EFI wide body red/ Slightly modified ![]() SOLD
Bill, thank you for your help. Will be placing the order shortly
Order Placed with Patrick, Now patiently waiting.
Banned
Patrick Motorsports will be your best friends for this conversion haha.
![]() I noticed that no-one has commented on fuel lines for this 3.6 engine swap. The fuel system in the SC uses M14 Fittings & Hose while the 3.6 993 motor uses M16 fittings throughout. If you keep the stock Fuel Filter, I have the correct Metric fittings & E-85 rated "Direct Connect" Hoses to make this job an easy one......... ![]() ![]() For information on these components or for any other Metric Fuel or Oil Hose questions, please email me. Len at Autosportengineering dot com
You Da Man. .when I attempt this conversion. I know another source to contact. To the original poster, any further up dates? Enjoy your week |
Len thank you, i think in the order above i ordered fuel conversion as well. I will be changing the filter and the fuel pump. But if i will ran into a problem i will contact you
![]() Quote:
So weekend went well. Was able to go Autocrossing and get some work done on the car.
Administrator
Here are some inspirational sounds for you. A 1995 993 in an early tub.
https://youtu.be/t7fASUvUIxY
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
