POVI's Avatar
Help needed on 3.6liter rs clone
Hello everyone ,
I need a little help on 2 items on my 3.6 liter 1970 rs clone
im building..
1/ does anyone have a picture they could post on how the front 2 batteries are held down in the battery boxes please ..as i dont see how they are held in place ...what am i missing , actually
i am missing the hold downs .. and need to see what i need to get !
2/ Im installing a one peice rs front bumper assy .. is there any seal needed between front bum[per and body ? .. and pictures please
Thanks to all in advace ..
- Joe -
PS 3.6 liter motor and 1986 915 with limited slip and oil pump cooler installed this weekend , almost ready to fire her up !
Old 11-18-2002, 09:27 AM
CamB's Avatar
Wow - cool sounding setup!
I don't have the answer to either question (well, I think the answer to #2 is nothing and to #1 is a metal bracket with a catch which "flips" over, a bit like the top on an old-school bottle like your grandparents used to fill with home-made cider.
My question is as to what people use as an alternative (mine (a single) is sorta wedged in there by the jack against the spare tyre - hardly ideal). I don't have the strap and I am missing at least one of the brackets on the body.
Cam
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 11-18-2002, 01:02 PM
Chuck Moreland's Avatar
Here is a picture of the '73 tie down, I think it is the same:
There is a thick rubber strip between bumper and fender, sorry no pictures.
Chuck Moreland - elephantracing.com - vonnen.com
Old 11-18-2002, 01:20 PM
Bill Verburg's Avatar
When I did my RS clone way back when(this was in the early 70s) I either used the existing stock rubber pads or nothing at all between the f/g and steel.
Your car will be set up like mine
Bill Verburg
Old 11-18-2002, 01:38 PM
POVI's Avatar
Hi
Are those batteries suposto sit in the boxes sideways like that ?
with the terminals laying out side ways ???
Whgat about battery leaking fluid ??
I thought you would put them in standing up ?
Please advise
Joe
Old 11-18-2002, 01:51 PM
Senior Member
Joe,
Those are sealed batteries. Not sure you can put them in like that but if you could he would know as he sells them! Check out Chucks website... they are also a lot lighter than normal as well!
JoeA
Old 11-18-2002, 02:40 PM
That's a dry cell and it can be mounted on its side like that, no fluid to leak!
Old 11-19-2002, 07:52 AM
