Cyclops Light Help
Does anyone have any suggestions for finding the problem with my cyclops light (third brake light).
Bulb is ok, no voltage to the light with brake applied.
Standard brake lights working fine.
Is there an additional brake switch for the cyclops light?
Hopefully someone has solved this already so I can save some time debugging. Thanks in advance.
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 11-18-2002, 07:18 AM
Had the same problem on my '88. Traced it to a 2 prong rubber connector in the engine compartment, driver's side below the wing nut/black plastic cover just aft of the coil. Previous owner had disconnected it for whatever reason. Plugged ends back together and it works fine. (Note: I have the interior light at the top of the rear window; don't know what 86's have but the connector might still be the same as there's a good chance yours also ultimately connects to the left rear taillight assembly).
Argo
88 Targa
Old 11-18-2002, 10:38 AM
Argo,
Thanks for the tip, but that connector is OK. I cleaned the terminals and replugged, but still no cyclops light.
I'll trace further, unless someone else has a tip.
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 11-18-2002, 02:35 PM
check the voltage at that plug. it will give you a sense of direction.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 11-18-2002, 03:40 PM
It was a disconnected three prong connector in the same area. Appears that this connector may also carry the current for the rear window defogger.
I've got to get me a wiring diagram.
Argo, perhaps it was the same connector you were referring to. Thanks!
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 11-20-2002, 05:28 PM
