If the thermostat's max cooling position isn't "calibrated" to cycle the compressor off in the conditions you stated, "frosty pipe", the high side will be extreme and will PUSH more refrigerant through the ("never fully closes") TXV than its design specs call for. Last edited by wwest; 08-16-2015 at 02:00 PM.. |
Banned
This is mine. Totally stock 89. Just purged and charged r12. Posted on rennlist too. Anyway this is about 90 outside temp on highway at 70mph and running on level 2 for about 30 minutes. Keeping the cabin cool for sure. Hot this weekend! I'm in SoCal.
El Duderino
If you are going to consider tinting, then look at 3M Crystaline. It provides better heat mitigation and is not dark colored like other tints. Should you ever decide to install it, make sure you find an authorized 3M installer that will provide a warranty. 3M has a lifetime warranty on the product as long as it is installed by an authorized installer.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Banned
Banned
[QUOTE=RNajarian;8755478]Another scorcher today in L.A. Took the car for another whirl, temp rose ~10 degrees as before, pulled over as you suggested . . . And voila the outlet pipe was frosty.
Likely on the way to a complete freeze up. Maybe time for one of these ![]() any one wanna help put it in? [/] I put the thermostat around 1 on the highway and 2 around town. Keeps it in the hi 30s. In Redondo beach now, just visiting, sooo dry compared to south Fla.! Driving around Palos Verdes today Draco! Didn't see you
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
You do not have to 'calibrate' the stock thermostat.
You just have to have the probe located properly in the evaporator. |
El Duderino
I got a quote of ~$600 for my car (coupe). I don't know how that compares to other tint products.
I haven't done it yet but am considering it.
BLUF (Bottom Line Up Front)
I am a little late to this, and having just gone through a rather painful (and successful) A/C rebuild (which I will do a write up on soon) I thought I would chime in on issue I was having with my new system...which was vent temps slowly creeping....here is what I learned.
I could go on and on.....but what's the best setup for max cooling with no icing?
So how do I achieve the above noted condition?
On my car I cannot get the thermostat TO the 3 o;clock position. There is will not cycle properly, even on the freeway. At about #4 on the dial (just above 3 o'clock) my vent temps are regularly in the low 40's....sometimes in the high 30's. I also have found that, for the most part, the thermostat setting that works well does not change as the outside air temp does. This makes sense as they thermostat sensor only cares about the evaporators temp. Also remember that our cars are recirculate only. This means the lower the inside air temp is the lower the vent temp will be, to a point.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles Last edited by Duc Hunter; 08-17-2015 at 10:17 AM.. |
"If the thermostat's max cooling position isn't "calibrated" to cycle the compressor off in the conditions you stated, the high side will be extreme and will PUSH more refrigerant through the ("never fully closes") TXV than its design specs call for."
Nope, I never stated that, implied that or suggested that. Weird! Last edited by kuehl; 08-17-2015 at 10:08 AM.. |
Duc/Chris,
Well done, excellent write up. Adding an indicator light downstream of the thermostatic switch would make your procedure easier. A LED can be used if you somehow "squelch" the inductive voltage spike from the high Q clutch coil as the voltage is switched off. PS: the metering valve, TXV, is on the evaporator inlet pipe, the "pigtail" sensor is on the outflow side. Last edited by wwest; 08-17-2015 at 01:04 PM.. |
And there is post #31.. "1. Find the thermostat setting..."
Willard is trolling again.
{QUOTE}I put the thermostat around 1 on the highway and 2 around town. Keeps it in the hi 30s.
In Redondo beach now, just visiting, sooo dry compared to south Fla.! Driving around Palos Verdes today Draco! Didn't see you {/QUOTE} Fan speed or thermostat setting/position? If you're getting high 30s in thermostat position one or two then you probably get freeze-up above 5. Damn Good A/C in any case. |
Banned
I thought the TVX (EV) sensor was on the input line as that is the one that gets frosty...meaning it is colder???? The line with the valve in it never develops frost, meaning it is warmer...i.e. above the dew point of the trunk?
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
The TXV inlet is exposed to "hot" (~105dF) liquid refrigerant and the outlet to vaporizing refrigerant. The "sum" is sometimes below dewpoint so you will often see condensate in parts of the TXV. *** As the gas inside the pigtail cools more and more the TXV spring is able to overcome the gas pressure in the diaphragm and push the valve opening toward closing. You might be confused by the EPR which is used downstream of the evaporator |
