wwest's Avatar
Originally Posted by RNajarian View Post
Another scorcher today in L.A. Took the car for another whirl, temp rose ~10 degrees as before, pulled over as you suggested . . . And voila the outlet pipe was frosty.
Likely on the way to a complete freeze up.
Maybe time for one of these
any one wanna help put it in? ��
First, follow CG's instructions, turn the thermostat CCW until the compressor clutch circuit opens, shouldn't take more than 10-15 degrees.
If the thermostat's max cooling position isn't "calibrated" to cycle the compressor off in the conditions you stated, "frosty pipe", the high side will be extreme and will PUSH more refrigerant through the ("never fully closes") TXV than its design specs call for.
Old 08-16-2015, 12:24 PM
Banned
Prove it.
Old 08-16-2015, 03:24 PM
This is mine. Totally stock 89. Just purged and charged r12. Posted on rennlist too. Anyway this is about 90 outside temp on highway at 70mph and running on level 2 for about 30 minutes. Keeping the cabin cool for sure. Hot this weekend! I'm in SoCal.
Old 08-16-2015, 03:37 PM
wwest's Avatar
Originally Posted by SilberUrS6 View Post
Prove it.
What??
Wow, here I am restating, echoing, CG's statements and you say...
PROVE IT!
Ask CG....
Old 08-16-2015, 03:38 PM
El Duderino
tirwin's Avatar
Yes the additional surface area of the glass does increase the cabin temperature.
But it isn't unbearable. Tinted windows would help
If you are going to consider tinting, then look at 3M Crystaline. It provides better heat mitigation and is not dark colored like other tints. Should you ever decide to install it, make sure you find an authorized 3M installer that will provide a warranty. 3M has a lifetime warranty on the product as long as it is installed by an authorized installer.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 08-16-2015, 04:19 PM
Banned
What??
PROVE IT!
Ask CG....
Supply links and quotes.
Old 08-16-2015, 07:06 PM
Banned
It is expensive, both the product and the installation.
Old 08-16-2015, 07:07 PM
ganun's Avatar
[QUOTE=RNajarian;8755478]Another scorcher today in L.A. Took the car for another whirl, temp rose ~10 degrees as before, pulled over as you suggested . . . And voila the outlet pipe was frosty.
any one wanna help put it in? ��[/]
I put the thermostat around 1 on the highway and 2 around town. Keeps it in the hi 30s.
In Redondo beach now, just visiting, sooo dry compared to south Fla.!
Driving around Palos Verdes today Draco! Didn't see you ��
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 08-16-2015, 09:36 PM
kuehl's Avatar
You do not have to 'calibrate' the stock thermostat.
You just have to have the probe located properly in the evaporator.
Old 08-17-2015, 04:01 AM
El Duderino
tirwin's Avatar
I got a quote of ~$600 for my car (coupe). I don't know how that compares to other tint products.
I haven't done it yet but am considering it.
Old 08-17-2015, 06:00 AM
BLUF (Bottom Line Up Front)
  • You can only run your system as cold as where the thermostat switching the compressor on/off regularly or you will see icing, unless you are in a very dry climate.
  • When the compressor shuts off during normal cycling behavoir I am seeing a 10-15 degree increase in vent temps. This happens faster than an "Expansion Valve/Icing" situation (as described below). During the off cycle any ice built up on the evaporator melts off, as the evap temp rises well above freezing.
  • On the freeway you can run colder thermstoat settings, and still have the compressor cycling, than you can around town.
I am a little late to this, and having just gone through a rather painful (and successful) A/C rebuild (which I will do a write up on soon) I thought I would chime in on issue I was having with my new system...which was vent temps slowly creeping....here is what I learned.
  • If your system gets very cold, let’s say 42 vent temps, and stays there for a while but then starts to climb slowly…..and does not stop even as it passed through 65 (if you are that patient)…and the compressor is not cycling/shutting off for a bit....you have the thermostat/system to cold. The Expansion Valve (EV) is slowing the refrigerant flow to help prevent icing. However it cannot totally prevent icing (in my humid climate) and it opens/closes slowly. So the temp will just keep creeping up. This also causes the compressor to work harder as it is pushing against the closing EV. I call this an EV/Icing event.
  • If you have actually iced the evaporator (as I have done a few times) you will notice less airflow out of the vents AND the temp creeping. I also noticed very little-to-no water dripping out under the car. If I let the system sit for 10 min and then turn it on water is POURING out of the evaporator, like a hose is in there.
  • If I am on the freeway I can keep turning mine down to get high 30's-low 40's vent temps AND have the thermostat click the compressor on/off. This prevents icing and enables colder vent temps then when I am on 45 mph roads with stop lights etc (not stop/go traffic). This is because when the thermostat goes off, the vent temp will rise 12-15 degrees and does so more quickly then when the EV starts to close. This warmer air blows out any ice that has built up when the compressor was on, and really does not hurt the cabin temps. Sometimes I can smell the moisture, as it comes off the evaporator, as the system cycles in this state.
I could go on and on.....but what's the best setup for max cooling with no icing?
  1. Find the thermostat setting that shuts off your compressor when your evaporator reaches 32 degrees. This will prevent icing and should give you pleanty cold vent temps.
  2. On the freeway you can get evaporator temps below 32 without icing, AS LONG AS the thermostat cycles the compressor on/off regularly to let the system come up to high 40's-low 50's before kicking back on, as this will melt out any ice that may have built up each cycle. On slower roads though I have found this setting does not permit the thermostat to cycle in my climate, which then creates the EV/Icing issues described above. Once that issue is present I have to turn the system up (like almost to the warmest setting, to get the compressor cycling regularly again) pretty quick, or I get to a place where the temp just creeps.
  3. I have learned that humidity DOES matter, contrary to what many so-called expert say. Here in Florida I cannot run evap temps below 32 for any real period of time without icing, PERIOD....unless I am on the freeway. At full cold, even on the freeway I can cause an EV/Icing event within 15 min…even when it is 100 degrees out. A friend in Az (no humidity) can get evap temps below 32 as he does hot have enough humidity to build ice, in fact he can get mid 30’s vent temps. My car can be pissing water like a hose where his will barely drip. Also remember the action of the EV may prevent the icing in non-humid climates, but I have not seen it be able to do so in my humid climate on many cars.
So how do I achieve the above noted condition?
  1. I currently have a digital cooking thermometer sensor on the input line of the evap. This is the same line that has the Expansion Valve’s sensor (not the valve, the valve is in the output line), meaning the line in the smugglers box that gets water/ice on it. The wire is run back in the car so I can see the units display.
  2. I have been driving down the freeway, turning the thermostat down until I get the 32 degrees...trying to find that point where it shuts the compersor off at 32. Once achieved I note that position as my "MAX" setting.
  3. I then drive around town (not stop/go) to watch the evap temps. I need to ensure that around town it still cycles the thermostat at or just above 32.
  4. IF YOU ARE IN A NON-HUMID CLIMATE (Az, Ca, Australia, etc) then you could experiment with colder settings below the one found above, again because your humidity is so low icing will be less of a problem.
  5. I have heard that there is a refrigerator switch that could be placed on the input line or the evaporator. These switches apparently open at 32 degrees, which if connected inline to the wire that the thermostat uses to cycle the compressor, would switch the compressor off at 32, no matter your thermostat setting. This would prevent icing completely, and I may investigate this.
On my car I cannot get the thermostat TO the 3 o;clock position. There is will not cycle properly, even on the freeway. At about #4 on the dial (just above 3 o'clock) my vent temps are regularly in the low 40's....sometimes in the high 30's. I also have found that, for the most part, the thermostat setting that works well does not change as the outside air temp does. This makes sense as they thermostat sensor only cares about the evaporators temp.
Also remember that our cars are recirculate only. This means the lower the inside air temp is the lower the vent temp will be, to a point.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 08-17-2015, 09:04 AM
kuehl's Avatar
"If the thermostat's max cooling position isn't "calibrated" to cycle the compressor off in the conditions you stated, the high side will be extreme and will PUSH more refrigerant through the ("never fully closes") TXV than its design specs call for."
Nope, I never stated that, implied that or suggested that.
Weird!
Old 08-17-2015, 09:05 AM
wwest's Avatar
Originally Posted by griffiths View Post
"This is at 70mph at 85-90 outside temp (strong sun)".
For a stock R12 system, 42F is pretty good; you will
have losses between the evap and the vent, just like
losses between the flywheel and tires.
You indicated you had 30 inHg on the low at idle.
So that tells you that you have a cold evap core.
You can't get much more heat transfer with the
stock evap so the thermostat will keep asking for
more.
And, I'd suspect you still have some air
in the system (email to chat about that).
If you are happy with that result, I'd suggest
just a set of barrier hoses, orings, binary pressure switch,
drier, upgrade the evap, toss in a Kuehl vent, maybe
open up the compressor while the system is empty
and inspect the bores, pistons and wobble plates,
if all is well toss in a new seal and oring set.
If you want colder, feel free to drop an email.
Old 08-17-2015, 11:01 AM
wwest's Avatar
Duc/Chris,
Well done, excellent write up.
Adding an indicator light downstream of the thermostatic switch would make your procedure easier. A LED can be used if you somehow "squelch" the inductive voltage spike from the high Q clutch coil as the voltage is switched off.
PS: the metering valve, TXV, is on the evaporator inlet pipe, the "pigtail" sensor is on the outflow side.
Old 08-17-2015, 11:07 AM
wwest's Avatar
Originally Posted by kuehl View Post
RNajarian,
Nice write up.
A 10F rise in vent temp could be the evap core is starting to ice "partially", reducing
the effective surface area of the coil.
To take that supposition out of the possibilities, when it happens again quickly
pull over to safe place, leave the system running, pop up the front trunk, pull back the carpet, open the smuggler's box lid and see if the evaporator outlet pipe has iced up.
If so... the easiest quick fix is to turn back the thermostat a few clicks.
The thermostat should turn off the compressor clutch at some point moving CCW,
if it does not, keep turning it to full CCW, if the compressor stays on then its time for
a new thermostat (I just had a client drop off a basket case of parts to put in his car
and his 'new' old stock thermostat was shot; always on. )
..at some point..
And there is post #31..
"1. Find the thermostat setting..."
Old 08-17-2015, 11:25 AM
kuehl's Avatar
Willard is trolling again.
Old 08-17-2015, 11:58 AM
wwest's Avatar
{QUOTE}I put the thermostat around 1 on the highway and 2 around town. Keeps it in the hi 30s.
Driving around Palos Verdes today Draco! Didn't see you ��{/QUOTE}
Fan speed or thermostat setting/position?
If you're getting high 30s in thermostat position one or two then you probably get freeze-up above 5.
Damn Good A/C in any case.
Old 08-17-2015, 12:00 PM
Banned
Always.
Old 08-17-2015, 12:01 PM
Duc/Chris,
This is true....and I don't really need one as I can hear my new switch click on and click off, and unless I am on the freeway with the blower on full power, I can hear the compressor run.
I thought the TVX (EV) sensor was on the input line as that is the one that gets frosty...meaning it is colder???? The line with the valve in it never develops frost, meaning it is warmer...i.e. above the dew point of the trunk?
Old 08-17-2015, 12:13 PM
wwest's Avatar
The pigtail sensor is used to "tell" (***) the TXV that the COLD has propagated to the outlet therefore the evaporator core is at the low limit that the TXV will ("should")allow.
The TXV inlet is exposed to "hot" (~105dF) liquid refrigerant and the outlet to vaporizing refrigerant. The "sum" is sometimes below dewpoint so you will often see condensate in parts of the TXV.
*** As the gas inside the pigtail cools more and more the TXV spring is able to overcome the gas pressure in the diaphragm and push the valve opening toward closing.
You might be confused by the EPR which is used downstream of the evaporator
Old 08-17-2015, 12:31 PM
