I would rather be driving
Help. Need 930 transmisison fastener torque value
Hi, reassembling a 930 transmission after new syncros and a few other wear item replacement.
Can someone tell me the torque value for the: bearing retainer plate (is it the same as a 915?) input shaft main nut pinion shaft main nut Thanks
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Plate 16-18ftlb
30mm MS collared nut 160-170ftlb 20mm MS collared nut 120-130 ftlb 24mm Pinion collared nut 180-190 ftlb
Thanks John.
I had 2 of 3 correct. I thought 110 for the 20mm nut. Always good to verify. Now I can finish it all up. |
