Tired Member
DaddyGlenn's Avatar
Need source or replacement option for "J" clip
I'm finally at the point of bolting on a couple body panels and find that I am missing a few "J" clip nuts.
Not sure what to call the panels but they bolt on to the rear corners...
The right side (shown above) had M6 bolts and nyloc nuts from a repair done by a PO. It was a real PITA to get at the nylocs. The left side had the proper "J" clip nuts and, I believe, M4 bolts.
I'd like to replace the hardware but I cannot for the life of me find a source for metric "J" clip nuts in anything close to the right size.
I've tried Bel-metric, McMaster-Carr and a a few other places that came up in a Google search.
Does anyone know where I can find these? Or alternately, has anyone successfully used another fastener, that only requires access from below? I considered a "U" clip nut but the lower panel has clearance for a "J" not "U". Anyone use the "U" type?
Thanks in advance.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 08-16-2015, 03:00 PM
ROW '78 911 Targa
timmy2's Avatar
Bottom of page 4 looks promising here:
"U" & "J" Nuts Auto Body Clips - Auto Body Clips
More on other pages as well. They show metric, but none in the J form.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-16-2015, 03:04 PM
Tired Member
DaddyGlenn's Avatar
Thanks Dennis. I look at that site and that nut. It is 1/2" from center of hole to edge and what I need is closer to 3/8". That doesn't seem like much difference but space is tight. Also since all of my tools are metric, I'd like to keep to nuts and bolts that my tools will fit.
Glenn
Old 08-16-2015, 03:09 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Aircraft spruce
http://www.aircraftspruce.com/menus/ha/nut_clip.html
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-16-2015, 03:27 PM
I've these two saved. The second has some offerings in stainless....
ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners
Spire Nuts- 'U' type | Classic Car Parts
'90C4
Old 08-16-2015, 04:47 PM
It may be a little crude, but on the occasions of needing a J-clip, and only having U-clips in stock, I just cut the U-clip down to make a J-clip.
1979 911 sc coupe
Old 08-16-2015, 09:38 PM
Stainless is for boats, dissimilar meta corrosion will eat your panels and leave nice shiny stainless fasteners on the ground.
Old 08-17-2015, 12:37 AM
Tired Member
DaddyGlenn's Avatar
I was thinking of that option, too.
Glenn
Old 08-17-2015, 04:19 AM
Dave Kost's Avatar
Try West Penn Laco or McNeely AutoBody. They should have that J clip.
Dave K
Old 08-17-2015, 04:43 AM
cycling has-been
bkreigsr's Avatar
ECS Tuning
Search SiteSearch N0154581 - ECS Tuning
Bill K
Old 08-17-2015, 05:45 AM
