Front impact tube support bracket - RUST AGGGH
Hi there
I recently removed my front wings and on one side the drain channel was blocked by a stone (where the blue arrow points). It has caused the support bracket and inner wing to RUST. I have seen some detailed pictures of the repair process. However I am not sure how I remove the bracket (A). I think it is spot welded and its a case of drilling out the spot welds. Is this correct? Any other thoughts on this? Thanks Ed
Yuup that happens.. I have to fix luckly just the drivers side on my 930. Was looking into this earlier this year and came across this post in the paint and body work section which seems to be the right way to take care of it. Good luck!
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/565023-talk-me-through-rust-repair-please.html
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
Yeah it's spot-welded on. Quite a few of the buggers too...
Is the bracket A available as a repair panel from our host? They don't seem to stock it.
Ed |
