Jiggling distributor cap affects engine RPMs
I've been trying to troubleshoot the backfire issue with my new 911. After poking around the distributor I found this. Please see attached video.
https://m.youtube.com/watch?v=mk95fcGsrzA&feature=youtube_gdata_player |
A couple of thoughts:
The trigger wire at the back of the distributor is very close to a metal oil line. Make sure that it is not touching it and is properly insulated. Your HT leads are very close to the left hand cooling tin which also is rubbed away to bare metal. I would guess that the spark has a much easier job jumping to the metalwork rather than going all the way to the spark plug. Look at the engine running in the dark. You will see stray sparks if you have a problem. |
Member 911 Anonymous
How does the cap look underneath and are the retainer springs worn/loose?
Post some pics, because vid of dizzy does not look correct at all.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
![]() ![]() I have looked for arcing in the dark and have even used a grounded screwdriver to poke around the spark plug wires without finding any issues.The retaining clips seem slightly loose. ... Last edited by PPPP; 08-26-2015 at 04:43 PM.. |
Run!! It's a Marrelli!!
If the clips are loose, try bending them to tighten
tom
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
Isn't the dust cover underneath missing, it could account the the slop too???
Check parts pdf.
ROW '78 911 Targa
Here is a photo of my dust cover on my '78.
If you take the two rotor screws out and remove it, you can see the weights/springs. Might be worth having a look and cleaning them up. There is no dust cap. |
the CD uses ground as a trigger to fire the plugs.
the ground path is thru the plate of the points, dist, eng and back to the CD. i cleaned all this up on my 77 and it helped. my problem was more i noticed the engine would "drop out" if i moved the dist. i cleaned the mouting place for the points, where the plate contacts the dist housing, the shaft where it contacts the block. it helped a lot. its just a matter of cleaning the tarnish off all the contact points. not sure how lose your cap is, but that may be an issue itself.
Thanks for the picture. Does the dust cover effect the distributor cap in its position when clamped down?
I think it does, because it acts as a spacer, without it you may have just too much slop. Verify with your year free pdf file PAG Parts Katalog
Sorry, I wasn't clear in my previous post. I meant that the Marelli distributor design doesn't have a dust cap.
T77911S: Thanks, I'll trace the ground path from the points plate and clean that up too! Last edited by PPPP; 08-28-2015 at 01:01 PM.. |
^^^ well it appears you do not have a dust cover per design.
Okay well here is the link to your year's PAG Katalog: Porsche Genuine Parts Catalogue - Porsche Cars North America GO to the bottom and find your year.
I doubt that you will get a cap for a Marelli for ten bucks. I doubt that you will FIND a cap.
Run the engine at night, turn the lights off, look for arcing. |
