Updating The Transmission Tunnel And Console to 964/993 style
Hi everyone. working on my backdate project and I'm trying to figure out if anyone has tried to install the 964/993 tunnel on an earlier car and if it requires an obnoxious amount of modification or not. It's purely cosmetic for me as I'm trying to avoid the long shifter in a rubber boot. I'm assuming I'd have to move some things around a bit, but has this been done before? Pictures(or instructions) would be great!
DB My mistress... http://forums.rennlist.com/rennforums/993-turbo-forum/786934-ruf-turbo-r-a-proper-introduction.html |
backdate project and adding a 964/993 tunnel contradict each other I think
![]() Embrace the backdate and stick with the correct look! By the way dig the Ruf!!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C Last edited by JacobS911; 08-31-2015 at 03:59 PM.. |
Reiver
^^^^ Why? Just because you can doesn't mean you should!?
De Oppresso Liber Strength and Honor 5th Legion |
Thank you both for chiming in and JacobS for the compliment! The reasoning behind looking into this is simple. The singer cars are my motivation for undertaking this project. I didn't want to backdate a 964 so here I am. It's a detail I'm looking into while I wait for everything to get done.... Which will never be fast enough! Sent from my iPhone using Tapatalk
Reiver
I doubt if Singer would use the tunnel if they worked on older chassis.....they just keep what exists on the chassis they use and 'backdate' around it.
It's actually one of the things I dislike about a 1/2 million dollar job.
Just searched it out to see if anyone has done something like this..some interesting ideas that may work for you.
Raising / relocating 911 shifter
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
Thanks JacobS, but that's too much work. I was really just looking to see if it was a simple mod that had been done before. It doesn't bother me at all with the shifter on the floor. Just going through options!
Max Sluiter
The tunnel is an integral part of the tub. You are talking about stripping the car down to a bare metal tub, then cutting out the spine of the car (using a jig to maintain the squareness of the chassis) then welding in a new tunnel and rebuilding the car.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
I really just wanted to install the console for cosmetic purposes. I don't want to cut up the car!
Banned
Better Bodies sells a fiberglass console just for this purpose
Wow, that's definitely not me. I'll be going to "endorse the backdate"!
DB My mistress... http://forums.rennlist.com/rennforums/993-turbo-forum/786934-ruf-turbo-r-a-proper-introduction.html Last edited by 993 770; 08-31-2015 at 11:18 PM.. |
Max Sluiter
OK, I thought you wanted to change the tunnel - it does increase the rigidity of the body by being taller. Changing the tunnel involves all that work. A console on the other hand would be cake.
