right or wrong?
"I even approve upgrading from 2.4 to 2.7 because you can go back to original pistons & cylinders. Cutting off original rear fender is not reversible - it's a permanent loss. "
The above was posted on another board. Silly me, I always thought a 2.4 case had to be machined to accept the larger 2.7 p&c set...one reason I never did it. So, what's the story? |
Friend of Warren
Ok was this Ian or Tabby that posted that bit of drivel?
Kurt V No more Porsches, but a revolving number of motorcycles. |
Paul ... just as you suspected, after a 2.4 case is opened up from 92 mm spigots to 97 mm for the 90 mm 2.7 Nikasils ... there isn't much 'shelf' space left to support 2.4 84 mm cylinders! Definitely NOT reversible!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
