BBS 16x7 RS157 and 16x8.5 RS131 Fiment
Hello everybody,
I'm looking to buy a set of BBS RS for my 87 911 Carrera. I found a Pelican member that has a set of two 16x7 BBS RS157 ET49 and two 16x8.5 RS131 ET56. I would like to know if this rims will fit on my 87 Carrera without any problem and if they will look ok with this offset. I know in here there are very smart people that can answer on my question. Thank you in advance. |
Rescuer of old cars
Need big spacers. Correct offset for 7" is 23, so you'd need 25mm spacers on front. For rear8.5" you want 10-12mm, so probably 40-45mm rear spacers would be necessary.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Fastest Hunk of Junk
You've found some 964 offset wheels, OP.
Arne's right, but I would never run spacers that big--not to mention, you'd be missing out entirely on the great low offset lips of wheels that fit the car sans spacers.
-Brent |
