rick (guest)
Guest
Posts: n/a
Hey there.. Can I replace rotors and calipers on '89 911 with 930 rotors and calipers without any other changes and is there any difference in calipers??
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-09-2015, 04:53 AM
Nick at Pelican Parts's Avatar
I am not 100% sure. I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
GeorgeM's Avatar
Yes, you can swap them out... and yes, there is a difference.
The fronts will bolt on, but you'll need "custom" rotors that will accommodate the different offset of the caliper. Places like VCI or Rennsport Systems have these rotors and can put a whole set together if you like.
In the rear, you can use a stock 930 rotor, but the mounting holes are different from the 930, so the caliper needs to be machined with new holes to fit. You'll also have to grind one of the mounting tabs off of the suspension arm. Hard brake lines will also have to be replaced.
Of course, you'll need a 23mm master cylinder and removal of the proportioning valve.
Also, depending on wheels, you may have to shave the cooling fins off of the front calipers.
I've had this setup for about 15 years and love it. The car is rather over-braked now (if that's possible), which is a great thing for track use.
This is from memory, so I may have missed a piece or two... like I think there are a couple of spacers in there somewhere... probably in the rear.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 09-09-2015, 05:11 AM
Cairo94507's Avatar
Call Eric at PMB Performance in Utah for braking options and opinions about what will and won't fit. He has supplied all of the brakes and associated hardware for my 914-6.
'71 914-6 #0372
'17 Macan GTS
Old 09-09-2015, 06:00 AM
