Desperately need help!
I was replacing my sunroof seals, when I discovered that a hack mechanic used 3M
Fast Tack Trim Adhesive, (08031) on my sunroof seal. The product which looks and feels like super glue, wicked into the seal, and oozed onto the top of the car by a millimeter or two in some places. Does anyone have a suggestion for a solvent that will dissolve that hardened cement? I need something that will absolutely work. The MSDS lists hexane as a solvent so I have ordered some. So far I've tried goof off, goof off CA debonder, acetone, and 25% nitromethane with no luck. Sent from my iPhone using Tapatalk
Ron 1988 Sunroof Coupe |
If you mean contact adhesive thats cleaned with normal
turpentine,but not sure if thats what the 3M glue your talking about good luck. |
Contact the glue manufacturer?
65 356SC Cab - 70 T Sunroof Coupe - 82 SC Targa - 86 Coupe - 87 Targa - all sold years ago 89 944S2 Daily Driver-Sold because...still thinking why. 73.5CIS Targa Shed Find -On the Road Again |
Bland
Call 3M. They have awesome technical support.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
3M actually makes what they refer to as General Purpose Adhesive cleaner or remover.
This is referenced on their adhesive directions, but I'm not sure if it will work on adhesive that has fully cured.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
I did check with 3M. They didn't even know that the MSDS mentioned hexane as the solvent. They suggested scraping and their general purpose adhesive cleaner, and possibly heat. My hexane arrives today so that is next on the list. Thanks for all the suggestions.
aircooled addict
if the glue has crosslinked, it is no longer soluble in anything. I would try using a claybar on the spot or even sand it off carefully then buff the finish back to life afterwards. solvent will likely make a mess of your surrounding finish. would you pour gasoline on your hood?
someday I will actually get to drive a 911 |
I'm not sure what crosslinking , is but that stuff is seriously cured. I do believe it will have to be wet sanded off at this point. I can not believe someone used that stuff on that part of a car. Every time I think about it my blood pressure goes up! I sure do appreciate all the input.
Check out Bob Smith 161 uncure. It available on Amazon inexpensively. At the least give the company a call. Good Luck.
Scott
87 Carrera Venetian Blue gone but not forgotten. |
Try 3M adhesive remover. Amazing stuff.
Well, an update. No solvent worked. I tried every suggestion. Now it is at Queen City Auto Rebuild where they will try to wet sand and repair as necessary.
As an aside, I spoke to the shop that did the damage, Farmer's Automotive in Indiana. His response was ""That's what I Always use". I'll be shocked if his negligence costs me a penny under a grand. Be warned. Sent from my iPhone using Tapatalk
