nkotselas's Avatar
Clutch pedal SNAPPED how to replace it?
My clutch pedal literally tore. The metal arm broke off about 4 inches up from where it connects at the base of the pedal assembly. I'm looking at this and not sure how to remove/replace the pedal.
Anyone know how to do it?
Nick
'78 Turbo Look w/ euro 3.2
Old 09-25-2015, 08:55 AM
911SC Tinkerer
merlinfe's Avatar
Probably going to have to replace the whole cluster to get to just the pedal. There is a pelican that rebuilds clusters, do a search in the classifieds.
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 09-25-2015, 09:16 AM
That is some pretty thick metal to just break...
Easiest thing would be to weld it in situ... Shouldn't be too difficult... Heck of a lot less work than replacing the whole thing...
Old 09-25-2015, 09:19 AM
Pedal cluster rebuild.......
Nick,
Remove the complete pedal cluster unit from your car. Clean and inspect for the broken pin. It is very difficult and tedious to fix and repair your collapsed pedal cluster in situ. This is a common maintenance or repair project for DIY'ers. Take pictures and post them.
Tony
Old 09-25-2015, 09:21 AM
nkotselas's Avatar
Yeah my clutch started sinking to the floor. After a couple more presses it just fell out into my hands. Heard it has happened before but I'm still quite surprised.
Welding may be an option. I live with a metal worker actually, but as he is visiting we have no access to tools. Anyone know where to borrow some welding stuff?
Nick
Old 09-25-2015, 09:24 AM
Is it the arm that broke or the pin? Trying to figure out how the arm would break, but thats what was mentioned...
nkotselas's Avatar
Arm was broken I'll upload a picture
Nick
Old 09-25-2015, 09:35 AM
nkotselas's Avatar
Nick
Old 09-25-2015, 09:36 AM
Ouch. You can weld that, but will need to disassemble the cluster most likely...
Old 09-25-2015, 09:45 AM
wolds's Avatar
Question is; why'd it snap?
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 09-25-2015, 09:57 AM
I got a whole new refurbished pedal box assembly from Bruce Stone. You can send in your old one as a core.
Old 09-25-2015, 10:06 AM
New-ish 911SC Targa Owner
pampadori's Avatar
How long did it take you to pull and reinstall the pedal box assembly?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 09-25-2015, 10:09 AM
You need to pull the pedal cluster, remove the rest of the clutch pedal and get it replaced or welded. Might as well replace the bushings while you have it apart.
Old 09-25-2015, 10:25 AM
I haven't attempted to install it yet . Hope to soon. On my list of projects.
Old 09-26-2015, 09:01 AM
If you get it out today I am at work till 4:30 in the park,I can weld it. I also have a bushing kit for the pedal cluster at home that i havent got around to installing if it is an emergency. PM me
Old 09-26-2015, 09:27 AM
Are you an OBGYN and you have a welder at work?
Old 09-27-2015, 12:50 PM
The clutch pedal is a standard replacement part
Bruce
Old 09-27-2015, 04:47 PM
same thing happend to me. I welded it in the car. bevel the edges protect the surrounding area no problem
Old 09-27-2015, 06:42 PM
I am only an OBGYN on my 911 because I am always up in the back end of her. I have a welder at work and i Know how to use it. But we dont have room to work on a car just parts.
Old 09-29-2015, 02:45 PM
