Steve F's Avatar
Wink 1981 SC 3.0 relay questions please
I'm trying to get spares together and had questions about the DME and both the round red and the round black relays.
Are they year specific or which range of years would work?
Cannot seem to locate the DME in our host's parts selection, perhaps it is under another description?
Do the red relays interchange with each other?
Same question for the black ones?
Thanks much,Steve
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 10-05-2015, 12:12 PM
El Duderino
tirwin's Avatar
81 doesn't have a DME relay. That is '84-'89.
All of the black ones are the same and yes, interchangeable.
You need a red fuel pump relay. There is only one.
Avoid the URO brand relays. It has been reported by several users that they have a high failure rate.
While you're at it get yourself an OXS relay (aka lambda relay).
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 10-05-2015, 12:35 PM
Steve F's Avatar
Thanks Tim, that explains why it's not in the catalog. The locations of the fuel pump relay and lambda relay please?
Old 10-05-2015, 12:41 PM
ROW '78 911 Targa
timmy2's Avatar
Lambda relay is under the seat at the lambda controller.
Fuel pump relay is red and is in the front fuse panel among all the other black relays
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-05-2015, 01:00 PM
Steve F's Avatar
Thanks again!
Old 10-05-2015, 01:02 PM
KarlM's Avatar
What does the OXS relay do?
Old 10-05-2015, 01:04 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Oxy Relay = Lambda Relay = Frequency valve relay = the black 1" cube hooked to the silver box under the passenger seat for 80-83 US SC's.
It provides power to a part that helps regulate control pressure. If control pressure is high, less overall fuel is delivered. Vice versa for low pressure.
The part is called the frequency valve and does it's regulating based on what the O2 sensor tells the silver (Lambda) box under the seat. If the O2 says it smells rich, control pressure is increased, less fuel. Then it's too lean and the process repeats. Rich, lean, rich, lean all day long if you are just cruising. However, the rich lean swing is very small. The intent is to keep the air fuel ratio in that 14.7:1 happy spot on average.
1981 911SC Targa
Old 10-05-2015, 01:25 PM
scarceller's Avatar
The Red top relays are same as the black capacity (AMPS) wise but the red ones have a suppressor diode built in. You can use RED can in place of black but not the other way around.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 10-05-2015, 01:28 PM
Time to revise or correct the name for this relay.......
KarlM,
For years people have been referring or calling this relay as OXS (oxygen sensor) relay. I would quess the translation have been carried over the years from German to English. This relay controls the FV (frequency valve) operation and has nothing to do with the OXS. The OXS sends voltage signal to the ECU and in turn activates the FV (ON/OFF) only if FV has power. And where does the power come from? From the S18 or S22 (?) through the relay that is controlled by power from terminal #30 (that supplies power to the FP).
In theory, when the FP is energized at terminal 30 at the FP relay and power is also delivered to the OXS/FV relay's coil to switch the power coming from the fuse. To better understand this logic, please refer to the factory wiring diagrams that would clearly illustrate that the oxygen sensor has nothing to do with the relay. Yet we call this relay as OXS relay instead of FV relay. It is just a name.
Tony
Old 10-05-2015, 01:52 PM
El Duderino
tirwin's Avatar
My original one was silver and it was some kind of metal housing. The replacement was made of black plastic. Just wanted to point that out in case the OP has a different one. Either way it's the 1in cube sized thing like Bob said. There's only one 1in cube thing under the seat so it's hard to go wrong...
Old 10-05-2015, 02:08 PM
Bob Kontak's Avatar
Good point.
My original had more of a metal frame or bracket that affixed it to the Lambda box with a screw, if I remember correctly. Kind of remember black cube with the bracket but you may be right. Still easy to find. New one just lays on the floor.
1981 911SC Targa
Old 10-05-2015, 03:23 PM
What relay
guys is something that only US models have my 81SC does not have anything under the seat.
Old 10-06-2015, 10:43 PM
CIS Lambda system.......
Imoto,
Your '81SC is probably a Euro or RoW model car and won't have any of this lambda unit we have been discussing. Cars designated for USA, Canada, and Japan markets have the OXS/lambda unit installed and none for the Euro or RoW cars including Australia and New Zealand.
Tony
Old 10-06-2015, 11:25 PM
Thanks tony thought that was possibly the reason
Old 10-07-2015, 12:48 AM
