scottb's Avatar
Question Cruise Control Troubleshooting
The cruise control on my 84 will not disengage when I hit the clutch or brake. My mechanic has adjusted the switch under the pedals -- still no good. It holds speed, and will accelerate, but won't disengage. Servo?
How should I troubleshoot this?
1984 Targa
Old 11-26-2002, 06:26 PM
Hi, Is your cruise control a vacuum or an electric unit?
If it is a vacuun unit, check the vent on the servo. It is operated by a solenid, controlled by the brain. I have seen inscects build a nest in there. After that, make sure the brake lamps have power at the switch and that the signal is gettin to the cruise brain.
That was a moment of sheer panic in a 928 when it would not release.
Hope it helps
Geoff.
Old 11-27-2002, 02:46 AM
