irl irl is online now
irl's Avatar
Send a message via AIM to irl
Side window seals confused??
I have a 75 side door with no side window seals and can't find a thread that helps me. On a new build I have put new felt channel inside the window frame but I can't understand the two pieces that go inside and outside along the window on top of door. The PET is confusing and when I look through parts on various sites I see rubber scrapers and felt pieces but various options. My 71 looks like it has felt inner and outer but I see a lot of rubber options online. Any help would be appreciated.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 10-29-2015, 10:17 PM
irl's Avatar
After tearing apart my 71, here is a cross section. Now to determine A, B, C, and trim clip parts
79 SC unmolested
25 GTS
Old 10-30-2015, 03:33 PM
A, clips onto your door
B, has clips that go into the door and
C slides onto the scraper. Don't cut it until you've put it on the door to verify the length
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-30-2015, 04:05 PM
irl's Avatar
I know that now that I have taken one apart Need to find the parts. Everybody calls them something different with diff part numbers and nobody has them all.
79 SC unmolested
25 GTS
Old 10-30-2015, 04:10 PM
irl's Avatar
79 SC unmolested
25 GTS
Old 10-30-2015, 07:31 PM
irl's Avatar
Here is the part numbers as shown on the PET.
fuzzy outer seal
Right 901-531-936-20
Left 901-531-935-20
Scraper outer seal
Right 911-531-932-02
Left 911-531-931-02
Inner fuzzy seal
Left and right 911-531-951-01
Door Moulding clips
999-591-326-01-M100
Qtr window seal strips
901-531-933-20
79 SC unmolested
25 GTS
Old 10-30-2015, 07:37 PM
