kinein's Avatar
Send a message via Yahoo to kinein
front passenger side lower then rest of car why?
I had some work done on the car recently, turb tie rods and steering box lowered to replace fuel line from fuel pump to firewall. Now the car is tilting to the right front end only. Also a alignment. I do have new shocks all around. The car is 86 911
1966 912 with 2.2 911 motor
1986 wide body 911
1995 993 Polar Silver
Old 09-12-2012, 10:40 AM
na2ub's Avatar
They must have messed with or mis-adjusted your front right torsion bar height setting. Its just involves turning a bolt, or possibly jacking up the front, resetting the torsion cap, and turning a bolt. Get a Bently manual or take it back to the shop to have them adjust it. No big deal.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 09-12-2012, 12:21 PM
ROW '78 911 Targa
timmy2's Avatar
Alignment without corner balancing?
Old 09-12-2012, 12:56 PM
Go-Kart Mozart
JAR0023's Avatar
Or corner balanced and that's what it took to get the weights right. Or corner balanced poorly.
OP, we need more details on the alignment.
J
Old 09-12-2012, 01:14 PM
kinein's Avatar
Bump
1986 wide body 911
Old 09-13-2012, 06:09 PM
Fleabit peanut monkey
Bob Kontak's Avatar
kinein - what is it that you are missing as far as information?
Also, you were asked for more data in post #4 regarding your alignment. Maybe respond to that request before bumping the thread up top again.
1981 911SC Targa
Old 09-14-2012, 04:53 AM
kinein's Avatar
No corner balancing was done. Just a alignment after the turbo tie rods and strut bar was installed. Also the steering rack was lowered to replace the fuel line..... thats it
1986 wide body 911
Old 09-15-2012, 10:41 PM
Bob Kontak's Avatar
An alignment would not allow this to happen.
Any dampening adjustments on the shocks that could make a difference? If stock Bilstein or Boge, I don't think so.
Absolutely sure both front strut inserts are the same part?
Does the 86 have those silly US bumper height adjustment discs on top of the strut housings? They are about 1/2 inch thick. Could one be missing?
Did the car have the bump steer discs under the steering rack? Not sure if that would cause a height difference.
Can you be certain the left side is not up making the right side look low?
Could a wrench have messed with the height adjusters thinking it was a way to gain access for the fuel line replacement?
You pics show the car "in transition" with an estimated complete date of last year. Is it finished (or closer) and have you driven it around to settle the suspension?
1981 911SC Targa
Old 09-16-2012, 06:21 AM
Allow the car to sit and settle down........
It would take a while to get the car to settle to it its final ride height after the car has been lifted for an extended time. Every time I lower the 911 cars from a lift, they all sit much higher than their normal ride height. The newer the gas shocks, the longer is resistance time to settle down. Keep us posted.
Tony
Old 09-16-2012, 06:31 AM
kinein's Avatar
well i have driven the car for over 3k miles since the work has been done. one day when i was walking into the house i looked back at the car in the garage and i noticed the height differences. it is about 1 1/2 inch difference from the passenger to the driver side.
when i am driving and looking out in front i can see the difference of the height of the car. i really havent been paying attention to the car until i saw that. meaning when i received the car back i had a crack in my rear driver side rim. so the car sat until the rim was fixed then i started drivin it daily to work. i am goin to call the wrench tomorrow and see whats the deal.
1986 wide body 911
Old 09-16-2012, 09:02 AM
kinein's Avatar
i just been caught up with daily stuff like getting ready for my wedding and the transition after. now since i am focused i started to notice the car and the issues, i am having with it.
1986 wide body 911
Old 09-16-2012, 09:03 AM
kinein's Avatar
they are boge shocks
1986 wide body 911
Old 09-16-2012, 09:04 AM
kinein's Avatar
Bump
1986 wide body 911
Old 09-18-2012, 05:31 PM
ROW '78 911 Targa
timmy2's Avatar
These cars are so light and sensitive to the height and alignment adjustments that an alignment without a properly weighted corner balancing may give you the symptoms you have.
Just read some of the posts others have made about adjusting their height to see what is involved.
My car sits a little low in the front on one side and needs a minor alignment adjustment. It is getting new suspension rubber this fall and will be professionally corner balanced and aligned at a very reputable shop. (once I rebuild everything)
Yeah, $400 seems expensive for an "alignment" but the end result will be exactly what the car needs to drive and handle correctly.
Just re-read your post about miles put on since alignment and other work done. That is far too many miles to take back to the shop. Maybe you hit a pothole and threw it off.
New rim and tire replaced? Taller tread and an imbalance in tire pressures perhaps? A small difference on one corner causes a big change in the opposite corner.
Take it to a pro that can set your car up right.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-18-2012, 09:18 PM
kinein's Avatar
This is the left side
1986 wide body 911
Old 09-19-2012, 07:40 PM
kinein's Avatar
Rightside
1986 wide body 911
Old 09-19-2012, 07:44 PM
classic_carrera's Avatar
Did you find out the reason why, i'm having a similar problem?
Old 10-31-2015, 05:30 AM
djpateman's Avatar
A sudden change in ride height could indicate a broken torsion bar.
The OP did not notice for 3K miles, so it is likely that it was very recent.
Quick test is to see if there is any spring action on the low corner; if not then that is a strong indication.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 10-31-2015, 12:54 PM
DanielDudley's Avatar
Say what ?
Old 10-31-2015, 01:08 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Rightside
Something seem wrong with this picture when compare to the left one. The bolt does not look centred.
Who Will Live... Will See
Old 10-31-2015, 01:39 PM
