steve 911T SWB..
early S caliper question
hi friends , i got a set front and rear calipers in a bunch of pieces .... the calipers have been rebuild and i was wondering witch type i got !!
i think they are early S calipers 69-71 as i do not find any circle ... if i did my researches well hahaha
here some pictures
would realy appreciate any confirmation or infos as i don t plan to use them but would realy lie to know what i ve got
the S ones i think..
Old 11-12-2015, 08:57 AM
tharbert's Avatar
Does a magnet stick to them? I think the "S" calipers are aluminum.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 11-12-2015, 10:53 AM
steve 911T SWB..
they are.... i weighted also the smaller calipers ....
Old 11-12-2015, 11:19 AM
patz's Avatar
Send pics to Eric Shea at www.pmbperformance.com or PM Bill Verburg on this list.
Old 11-12-2015, 01:33 PM
They look like early S calipers to me. I haven't seen any with the "TEST" stamp so I'd be curious what that is, but everything else points to an early set of ATE aluminum S calipers.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 11-12-2015, 02:23 PM
Functionista
manbridge 74's Avatar
Thinner "webbing" on sides of caliper indicates early S. Later versions were thicker and had a smoother look.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 11-12-2015, 03:39 PM
steve 911T SWB..
I think the test stamp is from the compagny that rebuild them....
Old 11-12-2015, 08:48 PM
steve 911T SWB..
yep, should be the one on the far right ...
Old 11-13-2015, 01:12 AM
djpateman's Avatar
They do look to be early, but not the earliest versions. The earliest versions did not have the notches cut out near the bleed nipples. Also, the earliest I have handled had the same circular machining on the inside of the mount ears as on the outside.
The TEST stamp is very odd, and not something I have seen. The experimental calipers have a "V" for versuch and a numerical identifier.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 11-13-2015, 03:50 PM
Enthusiasm > Expertise
reddogmotrsprts's Avatar
Who did the restoration of these?
Red Dog Motorsports
Old 11-13-2015, 07:30 PM
steve 911T SWB..
UDF Automotive did the Job :::
Old 11-14-2015, 03:27 AM
