85 Carrera Power Mirrors Don't Work. What to check first?
Just got the car. Mirrors don't work. Is there something common that we should check first?
1979 911SC Euro Tub/1982 Euro 3 Liter PCA E Class Race Car
1985 911 Carrera Coupe-Grand Prix White/Red
Old 11-20-2015, 06:19 AM
964TargaC2's Avatar
1. Fuse
2. Switches (motion and left/right)
I think that maybe I'm dreaming..
Old 11-20-2015, 06:33 AM
964TargaC2's Avatar
1. Fuse
Old 11-20-2015, 06:34 AM
Spiderman
Jesse16's Avatar
And after that, if its like my 87, you can access the the little mirror adjust toggle without removing the entire drivers door panel. Think you just take a screw or 2 off that top trim piece on the door. You can test for power and function there if you have a meter.
Last is start disassembling the mirror "carefully" so as not to break small/old plastic bits so you can check that the two little motors are able to work.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 11-20-2015, 07:17 AM
Thanks for the quick replies!
Since both mirrors don't work, I'm inclined to think it's the switch. I have my shop digging into it today. Fingers crossed it's cheap whatever it is
Old 11-20-2015, 08:46 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Most likely the ground wire has dislodged from the socket. Did you recently do some work behind the door panel or gauges.
There are 2 grounds on the door trim toggle.
'85 Carrera Targa
PCA/POC
Old 11-20-2015, 12:01 PM
Eng-o-neer
Tremelune's Avatar
For what it's worth...I manually moved mine into position as a stop-gap measure. That was years ago. Kinda forgot about 'em.
Old 11-20-2015, 12:33 PM
We did just have the door panels off to do new door checks and door check reinforcements, but both mirrors weren't working before they started that project. Here's to hoping it's something simple. Cheers
Old 11-20-2015, 01:31 PM
DRACO A5OG's Avatar
Check both the connector and toggle. You will see the metal tabs/connectors, insure they are seated properly and not dislodged.
In fact, check the voltage on the terminals to insure 12v's
'85 Carrera Targa
PCA/POC
Old 11-20-2015, 03:17 PM
