replacing 79sc distributor help
79sc, bad distributor.
I have a rebuilt distributor ready to drop in. Is this as simple as making note of where current distributor is, sliding out, sliding new one in exactly where rotor was, button up, double check timing.
Im guessing it should probably be put at top dead center, but how do I turn engine over by hand. If i turn alternator nut, the fan just spins not cranking the motor. There is no way to get to crank pulley bolt without taking exhaust off, dropping engine tin, and removing carrier.
Old 12-05-2015, 06:59 AM
steely's Avatar
You can use the alternator nut if you press gently on one side of the belt to take up the slack.
for your fist question, it was that simple for my 3.2 (drop in), but I don't have points to contend with. The O-ring may resist a little.
Make sure you're at TDC and the rotor is pointing to #1
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 12-05-2015, 07:27 AM
ROW '78 911 Targa
timmy2's Avatar
Try tightening your fan belt by one shim, maybe 2. It is a lot easier to adjust the belt to the proper tension than the other alternatives you listed.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
carrerarsr65
turn the crank pulley,with a long 19mm wrench do it all the time
Old 12-05-2015, 09:28 AM
wwest's Avatar
Your first statement/procedure is correct, just make sure the rotor is aligned to the same degree as the one removed, then use the distributor body rotational to set/correct the timing.
Old 12-05-2015, 11:32 AM
Yep, did this. Worked out fine!
Old 12-05-2015, 01:09 PM
Gordo2's Avatar
Spinning Crankshaft to TDC
Remove the plugs if you can't get the belt to grab good enough to spin the motor.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 12-05-2015, 06:49 PM
