What about one of those trick stack type electronic gauges that lets you have virtually limitless readings. You could have 6 CHTsd and 6 EGTs plus more. They arent even that expensive anymore. You could mount it on a flip down hinge under the dash and have no 2" holes.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
If you have enough gauges you won’t even have see it when you rear end the car in front of you while looking at a reading or fiddeling with the swiches.
![]() EGT and A/F mix are what you need to set up and monitor your motor. You can get an EGT probe that requires no welding you just drill a small hole in the ex pipe. Install the sensor within the first 6 inches of the ex port. BeepBeep is spot on CHT will tell you how the fan is doing but good EGT and A/F mix readings rarely also have high head temps on the average motor. Head temp and oil temp tend to go hand in hand anyway. (race or high peformance motors excluded) There is a good dual EGT gauge available, no fiddling with switches. You install one sensor on each side and while driving you can with only a glance see how both sides are doing and compare carb tuning and linkage setup as well. |
![]() Quote:
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Senior Member
OK...it looks like I will not be able to put in any EGT probes in the right position until I have a better reason to pull the motor or remove the SSIs. I do not see any plugged EGR ports on my heads.
I considered putting them on the exposed part of the SSI piping near the front of the car, which is probably the closest to the heads that is accessible. Would that location work? I will probably put in a dual EGT/CHT gauge and just run those leads later. My question for those monitoring CHT is, does it have any value? I think EGT is more direct, but have you found value in therms of monitoring engine health by monitoring CHT? Thanks, Olivier
Olivier Hecht 1982 911SC |
![]() Quote:
![]() Quote:
Senior Member
I definitely have the volt gauge to put in...I had been using the pilot display on my Passport 8500, but they're illegal in VA. (8500s, not volt gauges)
I think I will wait until I have the proper access for the EGT, especially since the senders are ~$27 each! In the meantime, I will monitor all 6 CHTs. I am leaning towards a dual gauge and a 3-position switch that will show me front, middle, and rear cylinders as pairs. My idea is to use this as a gauge of how the cylinders are doing compared to each other in terms of mixture, timing, cooling, spark, etc. I know there will be variation based on cylinder locations, but I should get used to the baseline readings fairly quickly. I am also going to put in a A/F gauge and probably a vacuum gauge in the engine compartment to facilitate tuning, etc. I am definitely sensitive to the issue of information overload, and I do not plan to switch between cylinder readings when driving unless I am diagnosing a potential problem. I don't even look at my speedometer most of the time, especially now that the 930s wheel blocks it almost completely. Olivier
wouldn't it be a cool if a single CHT gauge would sense all six cylinders and automatically display the one with the highest temperature.
This circuit wouldn't be too complicated to build...
Tony '78 911SC with BITZRACING EFI conversion kit |
![]() Quote:
Gentleman:
Heat in cylinder heads is produced by combustion, the very same combustion that EGT-sensor measures, directly. CHT is nothing but lazy way of measuring EGT that is also influenced by fan-RPM and much less "instant". Oil-temp is even more delayed and fuzzy measure of CHT, this time influenced by EGT, CHT, fan-RPM, airflow trough front cooler etc. Personally, i believe that EGT is the way of monitoring how engine feels and much, much more accurate and exact than monitoring CHT or even worse, oil-temp. I understand that CHT is cheaper, and doesn't involve drilling and welding-in EGT-probes, but you get what you pay for in this case. P.S. On the other hand, you have N/A motor, and EGT isn't as important as in turbocharged engine, where things can happend very fast and destroy engine.
Thank you for your time, |
![]() Quote:
Senior Member
I am assuming that relative temperatures (to eachother and some baseline when the engine's condition is somewhat known) is the most important, since I don't know of specific spec for each engine under each condition.
I would be much more inclined to do both or to do EGT if I could mount the sensors on the exposed part of the SSIs. Would this give me readings I can use in a relative manner? Or would they be off the scale on the low side and useless? The time pressure is because I will be running wires from the engine compartment to the dash area for other projects while I am cleaning and doing a lot of stuff in the interior. I just can't risk breaking an exhaust stud pulling the SSIs just for the EGT sensors. I like the point regarding CHT that it would show cooling fan or air ducting issues as well. EGT is certainly a more direct measure of what is going on in the combustion chamber, but I think CHT is valuable too, as it would show how all the systems designed to cope with the current temperature are handling it. (i.e. 1700 F EGT on a cool night with plenty of airflow may be manageable without damage, but lower EGT temps sitting in traffic could be more of an issue) My uninformed opinion... Olivier
CHT and EGT are both good to have. Each has its advantage and disadvantage. The nice part about having both is being able to recognize detonation. When an engine begins to detonate the CHT will increase and the EGT will drop. With such a set up you will be able to detect detonation long before you can hear it !
What kind of sensor are you guys using for CHT. Are the ones that go under the spark plug available (where?). Are they thermocouple or thermister based?
Navin Johnson
BINGO!!!!!! Ive heard that before. Porsche engines are much to noisy to hear detonation unless it is already doing damage.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Senior Member
Tony,
Aircraft Spruce and Wicks (aircraft supply) have good prices on 14mm CHT senders that go under the spark plugs. The gauges they both carry are also high quality and reasonably priced. I have been looking at all the Westach products they carry. Westach has a site at frostalarm.com, and they are helpful over the phone, but they were quick to direct me to the retailers and told me I would save close to 40% by not buying direct from them. The cool thing about Westach is that they will put together a dual (or triple or quad) gauge for you using existing "faces" they already have for no extra cost compared to a "standard" gauge with the same number of readings. They will also make custom faces, but that costs extra (like $50) and takes a little while. I was going through all kinds of combinations and I am still not sure what the best way to combine reading is. I may have air/fuel and trans temp as single gauges, and then a dual CHT/EGT gauge with a 6-position switch to display any one cylinder at a time. I would hook up the EGT later when I have better access and leave the gauge on the hottest cylinder (#3) while driving, but still be able to switch during tuning, health checks, or diagnosis. Olivier
![]() Quote:
..."combination"..haven't done full CHT & EGT install yet, but my concern is more engine damage than max HP tuning. like if a fuel dizzy or single carb gets fuel starved. I think 6 EGT probes w/constant monitoring is the way to go for tuning.. monitoring CHT for engine load is 1 probe, IMO.. but not individual cylinder load. and if "pinging", then all cylinders would be affected ... and when Don & Tim wrote "When an engine begins to detonate the CHT will increase and the EGT will drop" that confused me.. I figured that if a lean condition caused pinging that EGT would increase.. so, I guess that it's the total volume of EGT heat that decreases and indivudal cylinder load increases.........Ron
Oliver, have you made any progress on this project?
I am interested in a CHT gauge too, unsure about an EGT gauge, and interested to know what you found to be the pros and cons of X-way gauge with Y-way switch - e.g. dual CHT/EGT gauge with 6 way switch, etc.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Senior Member
A lot of my projects have been delayed, but I was actually thinking about this again this morning. I will probably put in the wiring while I am cleaning underneath the carpeting, etc., but my main concern is breaking an exhaust stud just to remove the SSIs to put in the EGT probes. It may not be worth the risk until I have a better reason to remove them.
I am also looking for a good way to mount the gauges that looks somewhat professional. The 3-gauge pod that Performance sells and describes as matching the 911 interior grain is just a piece of rubber that doesn't even seem to have the right angle for the dash. I am going to re-list my parts requirements today and think it through again.
