wannabee wannabee
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
Hmm...any deeper knocking I have heard was not temp dependent. The ones I have heard did not go away with RPM...their speed just increased but you could still feel them. That higher pitched valve tapping type sounds I have heard temp dependent (in my car). Strange one you have there.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
I had a knock/tick that sounded exactly like yours and recently had my wrench try to locate the source. He found my rockers and shafts were a little worn with with score marks one side.
My cams and rockers are headed out to be redone so I wont exactly know if its gone until they get back but I had my heads done around 7k miles ago and the shop reinstalled the rockers and shafts as is (they had 98k miles on them at that point. Good luck
$35 and a six pack to my name..... '88 Diamond Blue Carrera CE 3.4-SOLD
