Windshield seals in Miami
Hi all
It's been raining for 3 solid weeks in Miami and I've developed some foggy gauges, foggy third brake light, and some slight condensation under my rear windshield. I just finished replacing the tail light lenses, and given the state of some of the rubber, I think I need to go through and replace a bunch of seals. I've already purchased the fender to cowl seal from our host. Can you all recommend any others I should do? Trunk is done, engine compartment looks good. Does anyone know someone in Miami who can do my front and rear glass at a fair price? What price would that be? |
Is water leaking into the car from the windows?
If you replace them be sure thay are the more expensive OEM Porsche seals not the aftermarket seals. The gauges are not sealed and usually only fog up because of excess moisture in the trunk area.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Nope
I don't see any water leaking in, nor do I see any dampness, but the rubber around the windshield seems to pull slightly back from the edge in some sections and I see where someone put some rubber compound in there, I'd like to get them redone as a precaution.
The ones behind the rear glass are clearly due to where the rubber seals come together under the metal clasp. |
I have a targa and have gone through this here in Austin. Replacing seals definitely has helped me. Adjusting windows also (not your issue, but still.) I have not tackled my windshield seal yet, but I did go in and reinforce it with some 3M Bedding and Glazing Compound that someone suggested to me, and it seems to have slowed the leaks down a lot. Also, read the posts on here how your aluminum window trim (embedded in the rubber) is used to hold the windshield seal in proper alignment with the frame - important. You can shape/adjust it by tapping it with a wooden shim.
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
Safe lite on 8th street has a guy that has installed lots of them in mid year cars. They did my front and it doesn't leak. Call about prices.
Andy Bullen
So much rain in the last week - talk about moist
76 912E - Grocery Getter 04 Toyota TacomaTRD - Beater Truck 08 Honda OdysseyEXL - Family Hauler |
Cars and Cappuccino
Been in Miami for 4 days now...geez.....not even Hurricane season.....
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
For you Miami Pelicans... check out Miami Porsche Service and Repair
George is excellent. (Maybe today we'll see some sun!)
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Thanks for the great tips
I used to go to Mercedes Autobahn back in the day, there are a gang of decent mechanics around there. I will go check him out.
Looks like the sun is trying to peek out today finally. I was contemplating moving. |
Schleprock
Don't be reluctant to replace the windshield seal and the rear window seal. Both of these frames on the car are NOTORIOUS for harvesting rust. ANY signs from these windows that you have a problem with sealing should be taken care of.
The windshield is quite easy. The placement seal on the glass and aligning the curves in the seal with the curves in the glass IMO is a bit challenging. Use the old seal as a guide and mark the center of it on the glass (top or bottom of windshield, doesn't matter) with a piece of tape to give you a reference where the center/joint of your new seal should go. The hardest part is committing to a location and the actual cutting of a small hole in the seal to pass thru the annoying wire for the radio antenna!
Kevin L '86 Carrera "Larry" |
