| Registered |
				Clock quit working......
			1986 930 clock has stopped working. No power to terminal on back, where does the power come from...no, battery won't work for an answer thank you. Fuse is fine.
				__________________ 1986 930 2009 Harley Davidson FLHRCI Road King Classic 1998 BMW 328i convertible 2012 Nissan Frontier Pro 4X 2011 Nissan Xterra(wifes car) | ||
|  12-13-2015, 03:23 PM |
| Registered User Join Date: Sep 2010 Location: Not Virginia
			Not sure if you have the same VDO quartz clock in that thing, but if so here you go: The clock is ticking!
				__________________ 1980 911 SC targa 1959 Triumph TR3A - sold Something new is on the truck... | ||
|  12-13-2015, 04:41 PM |
| Registered |
			clock isfine there is no power at the terminal...is there a relay somewhere?
|  12-13-2015, 04:58 PM |
| Registered |
			From memory it is the same fuse as the interior lights on my 83 SC Tim
				__________________ Swapped my WRX Sti MY02 for a Porsche 911SC '83 Keep buying parts to make it look older. Mid life crisis is now in its 12th year. | ||
|  12-13-2015, 06:42 PM |
| Registered |
			Fuse is good, wondering if there is a relay somewhere
|  12-13-2015, 10:57 PM |
| Eva |
			Time for an oil pressure light
				__________________ '78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- | ||
|  12-14-2015, 05:24 AM |
| Registered |
			[QUOTE=911SauCy;8917033]Time for an oil pressure light   [/QU Oil pressure light?
|  12-14-2015, 06:48 AM |
| Eva |
			[QUOTE=Browzer52;8917169]
Yes.
|  12-14-2015, 07:13 AM |
| Registered |
|  12-14-2015, 07:17 AM |
| Registered |
			Do you mean to tell me the clock worked?   I've owned many P-cars and found the clocks to be a space taker - NONE of mine have EVER worked!! Having chased down that path a few times without success, now I wear a wristwatch! good luck - pls document what you find if you ever find it!! td | ||
|  12-15-2015, 02:19 PM |
| ROW '78 911 Targa |
			No relay, same power feed on black wire as the glove box lamp.
				__________________ Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. | ||
|  12-15-2015, 05:07 PM |
| Registered |
			There is a good chance the capacitors in the clock are leaking and need to be replaced. I sent mine to The Clock Works in Eagle River Wisconsin and had great service with a fast turn around time for less than $100. There are others that advertise on the internet.
				__________________ 1977 911S silver/black | ||
|  12-15-2015, 06:59 PM |
| PhD on Pending Projects |
			I will ask the obvious... Have you tried providing 12v to the clock and it works?  Meaning, running 12v directly to it. Are you testing the 12v on the existing wire harness correctly?
				__________________ Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet | ||
|  12-16-2015, 02:38 AM |
| Registered Join Date: Oct 2005 Location: Capistrano Beach, Ca.
^^This^^ Please let us know if your glove box light works. The closest diagram I can find shows a connector between the fuse and the clock/glove box light. If that connector is separated, no power to clock but also no power to the glove box light either.
				__________________ L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip | ||
|  12-16-2015, 07:13 AM |
| ROW '78 911 Targa |
			Also goes to trunk lamp and then to interior lights. I just repaired someone's '88 turbo harness that had a melt down of that circuit. Black wire runs from fuse panel to clock to glovebox lamp to trunk light and then to interior lights. Doubled up black wire at clock location should have 12 volts if fuse is good.
				__________________ Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 12-16-2015 at 07:58 AM.. | ||
|  12-16-2015, 07:53 AM |
