Browzer52's Avatar
Clock quit working......
1986 930 clock has stopped working. No power to terminal on back, where does the power come from...no, battery won't work for an answer thank you. Fuse is fine.
2009 Harley Davidson FLHRCI Road King Classic
1998 BMW 328i convertible
2012 Nissan Frontier Pro 4X
2011 Nissan Xterra(wifes car)
Old 12-13-2015, 03:23 PM
Brian in VA's Avatar
Not sure if you have the same VDO quartz clock in that thing, but if so here you go:
The clock is ticking!
1980 911 SC targa
1959 Triumph TR3A - sold
Something new is on the truck...
Old 12-13-2015, 04:41 PM
Browzer52's Avatar
clock isfine there is no power at the terminal...is there a relay somewhere?
Old 12-13-2015, 04:58 PM
Mothy's Avatar
Send a message via AIM to Mothy
From memory it is the same fuse as the interior lights on my 83 SC
Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 12-13-2015, 06:42 PM
Browzer52's Avatar
Fuse is good, wondering if there is a relay somewhere
Old 12-13-2015, 10:57 PM
Eva
911SauCy's Avatar
Time for an oil pressure light
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 12-14-2015, 05:24 AM
Browzer52's Avatar
[QUOTE=911SauCy;8917033]Time for an oil pressure light [/QU
Oil pressure light?
Old 12-14-2015, 06:48 AM
Eva
911SauCy's Avatar
[QUOTE=Browzer52;8917169]
Oil pressure light?
Yes.
Old 12-14-2015, 07:13 AM
Browzer52's Avatar
[QUOTE=911SauCy;8917219]
Originally Posted by Browzer52 View Post
Yes.
Thanks....
Old 12-14-2015, 07:17 AM
Do you mean to tell me the clock worked?
I've owned many P-cars and found the clocks to be a space taker - NONE of mine have EVER worked!! Having chased down that path a few times without success, now I wear a wristwatch!
good luck - pls document what you find if you ever find it!!
td
Old 12-15-2015, 02:19 PM
ROW '78 911 Targa
timmy2's Avatar
No relay, same power feed on black wire as the glove box lamp.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-15-2015, 05:07 PM
There is a good chance the capacitors in the clock are leaking and need to be replaced. I sent mine to The Clock Works in Eagle River Wisconsin and had great service with a fast turn around time for less than $100. There are others that advertise on the internet.
1977 911S silver/black
Old 12-15-2015, 06:59 PM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
I will ask the obvious... Have you tried providing 12v to the clock and it works? Meaning, running 12v directly to it.
Are you testing the 12v on the existing wire harness correctly?
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 12-16-2015, 02:38 AM
^^This^^
Please let us know if your glove box light works.
The closest diagram I can find shows a connector between the fuse and the clock/glove box light. If that connector is separated, no power to clock but also no power to the glove box light either.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 12-16-2015, 07:13 AM
ROW '78 911 Targa
timmy2's Avatar
Also goes to trunk lamp and then to interior lights.
I just repaired someone's '88 turbo harness that had a melt down of that circuit.
Black wire runs from fuse panel to clock to glovebox lamp to trunk light and then to interior lights.
Doubled up black wire at clock location should have 12 volts if fuse is good.
Dennis
Old 12-16-2015, 07:53 AM
