toddu's Avatar
WEVO shifter question
I've installed everything onto the shift base. I understand the laws of physics are working against me, but left to right movement is REALLY stiff. I imagine once it's attached back in the car it won't seem so "heavy"? I thought it was going to provide a little resistance.
Todd
'81 SC
Old 12-19-2015, 08:29 AM
gumba's Avatar
Install it and see how it feels. You can swap out the springs for different tension. I went with the stock springs for the race car, and lighter springs for the street car.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 12-19-2015, 08:59 AM
Gordo2's Avatar
Wevo Spring Tension
Normal - install and feel the love.
It is surprising how strong the springs are when you hold the base in your hand and move the shifter back and forth, meanwhile I think you will find the tension's just right with the base mounted.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 12-19-2015, 10:21 AM
toddu's Avatar
Thanks guys!! I now see Wevo sells a spring kit.
I'll get it installed and see how it feels. I imagine it will be fine.
Todd
'81 SC
Old 12-19-2015, 10:26 AM
evan9eleven's Avatar
Could hardly move the lever against the springs with the assembly in hand-- installed in the car its perfect for me. I suspect you'll find it to feel quite normal once installed. Good luck with the rest of the job!
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 12-19-2015, 03:19 PM
