sugarwood's Avatar
What does re-valving shocks accomplish? When is it needed?
I just watched this and had some questions.
When a shock leaks oil out, I understand that it no longer works.
What exactly is re-valving a shock?
What symptoms exist that indicate a shock needs re-valving?
At the 7:00 mark, he shows that he is replacing a bunch of washers.
What is the point of replacing washers?
I can understand replacing o-rings, but not washers.
It doesn't appear to be a complex part.
If a shock isn't leaking oil, and doesn't fail the manual bumper bounce test, it's working fine?
1986 Bosch Icon Wipers coupe.
Old 12-23-2015, 08:04 AM
Reiver
Reiver's Avatar
He's not rebuilding a leaky shock he's revalving to change the stiffness.
De Oppresso Liber
Strength and Honor 5th Legion
Old 12-23-2015, 08:59 AM
Rebuilding is required when the seals wear out.
Revalving is changing the piston orifices to get different shock forces at different shaft speeds.
A rebuild is necessary indeed if the oil leaks out, but also if the internal wiper on the piston fails. Basically if the shock isn't working so great anymore. They're wear items and don't last forever, nor do the usually fail all at once. They degrade over time.
A revalve is necessary if you change spring rates (torsion bars) a significant amount. It can be extremely complicated - back in the day, there was linear valving. Two one way valves and certain size holes. Force went up linearly with shaft speed.
Then came digressive valving, with multi-piece valving (shim stacks.) With digressive valving, forces ramp up quickly to give the good body control you get with stiff shocks, but "blow open" and knee off at high shaft speeds (bumps) for ride comfort.
Now cutting edge passive valving in the cubic megadollar range is using regressive valve curves - super fancy stuff that ramps up even faster at low shaft speeds, then actually more than just knee off but actually soften at high shaft velocities to let the suspension work to soak up bumps.
And then there's the active magnetorheological shocks, where there's a magnetic based fluid that can have it's viscosity changed several times a second by passing an electromagnet field over it. Neat stuff.
But I've gone too far. Yes, changing the valving on a shock isn't hard. Changing it to something that works for your application requires someone with pretty specialized knowledge.
Matt - 84 Carrera
Old 12-23-2015, 09:00 AM
Bill Verburg's Avatar
Not all shocks can be rebuilt or revalved
not all Bilstein shocks can be rebuilt or revalved
Bilstein mono-tube shocks can be rebuilt and revalved.
In these shocks both oil and the pressurized gas can leak, if they do seals will be replaced and the shock re charged.
If the shock damping curve is to be modified for different performance say because of a spring change or a desire for different behavior then a re-valve is needed.
Here are what the oil ports look like for different curves, the oil of course is forced through these ports, the resistance is what damps the motion.
Most older design shocks are linear(this includes all the Bilstein hd and sport shocks for 911), digressive is very popular for high performance and track use(Bilstein PSS are digressive), almost all new high end race shocks are digressive, Though at the bleeding edge other more esoteric strategies are used.
Here is what the shim stacks look like from the side
There are multiple choices for the shims, each has a different flow characteristic
Bill Verburg
Old 12-23-2015, 11:44 AM
Air Cooled
Craig_D's Avatar
Bill, you never cease to amaze, my man!
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 12-23-2015, 12:17 PM
sugarwood's Avatar
So, what was the point of replacing the shim stack in the video?
Old 12-23-2015, 12:27 PM
sugarwood's Avatar
Wait, does the "bounce test" even apply to torsion bar cars?
On other cars, it makes sense if the shock has no oil, there is no resistance, and a car will bounce on the coil springs when the spring decompresses.
I don't think a torsion bar would recoil and bounce in a similar way. For a torsion bar, when it's loaded, the bar twists, as it untwists, it should just snap back, if the shock damper is not working. But, it won't start to bounce, right? I'd imagine that a blown shock on a torsion bar car just means a sharper "bounce back". Is that right?
Old 12-23-2015, 12:30 PM
JOHN21BLACK's Avatar
Is there a formula for specs on a re-valve. I have a 2600 lbs car with 23/31 TBs. I want to re-valve my rear Bilstein sports. If I send to Bilstein to do this,what info do they need?
Old 12-23-2015, 02:33 PM
Jays72T's Avatar
Talk to Chuck at Elephant Racing, they re-valve Bilstien and test all shocks to match on a shock dyno.
Jay
'08 E350 Wagon
'74 914 gone
'72 T gone
Old 12-23-2015, 02:57 PM
gtc gtc is offline
abides.
gtc's Avatar
Torsion bars and coil springs behave the same.
Graham
1984 Carrera Targa
Old 12-23-2015, 03:17 PM
A coil spring is just a torsion bar wound into a cylinder shape.
A shim stack change is done to on a macro scale match a shock to a spring, on a micro scale change the handling characteristics of a car.
Matt - 84 Carrera
Old 12-23-2015, 05:43 PM
BFT3.2's Avatar
Elephant Racing refreshed & re-valved my 10 year old Bilstein sports to my new 22/30 TBs. Car handles great and controls the would-be faster rebound.
______________
'88 911 Coupe
'98 Spec Boxster
'85 380SL Benz -Euro
Old 12-23-2015, 07:16 PM
I installed Elephant Racing 21/27 TB's in my 82 SC without re-valving my shocks and I had porpoising in my car on one section of freeway which I've had porposing in various cars for this section of freeway. After having them re-valved by ER this went away and the care is much smoother. I provided them with the general setup of the car. Following the re-valving riders are surprised at how smooth it rides even with the upgraded TBs.
Old 12-23-2015, 08:47 PM
El Duderino
tirwin's Avatar
So I started reading this thread on my iPad and the first thought I had was "which thread was it that Bill Verberg posted that excellent picture in?" Scroll a little further down and there it is. Bill, you're like FedEx. Guaranteed to deliver.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 12-23-2015, 09:03 PM
Did you have front and rear re-valved with the 22/30 TBs?
Old 12-23-2015, 09:04 PM
BFT3.2's Avatar
If you mean me, yes absolutely.
______________
'88 911 Coupe
'98 Spec Boxster
Old 12-24-2015, 07:19 AM
ted ted is offline
likes to left foot brake.
ted's Avatar
fwiw even if an old shock seems fine the oil in the shock deteriorates with time.
Every few years we do a little preventive maintenance and have the JRZ, Penske and Ohlins rebuilt on our 3 race cars before they fail.
Old 12-24-2015, 07:28 AM
LOL,..That doesn't apply to anything and I'm sure it never did, much like kicking tires.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-24-2015, 02:30 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
So what would the recommended rebuild cycle be for Bilstein shocks on a street-driven car (years or miles)?
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 12-24-2015, 02:46 PM
sugarwood's Avatar
Are you saying you've never heard of this, or that it's not accurate?
https://youtu.be/BiW0ISi8N-w?t=44s
Old 12-24-2015, 03:01 PM
