The return of the magnesium block?
Great concept, but please note, "unfortunately, ceramic microparticles severely degrade the plasticity and machinability of metals".
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
To counteract this issue, researchers dispersed the particles into a molten magnesium zinc alloy. The newly discovered nanoparticle dispersion relies on the kinetic energy in the particles' movement. This stabilizes the particles' dispersion and prevents clumping. To further enhance the new metal's strength, the researchers used a technique called high-pressure torsion to compress it. "The results we obtained so far are just scratching the surface of the hidden treasure for a new class of metals with revolutionary properties and functionalities," Li said.'
I'm waiting for transparent aluminum.
Tru6 Restoration & Design |
Coram Deo
I read about it. It exists, at least in the lab. Let me see if I can find the link....
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
Undocumented User
Moving forward, in a 1.X liter twin turbo world the benefits at least as far weight savings is concerned seem very diminished.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Magnesium.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
JR |
that would be amazing to have a transparent engine block and be able watch whats going on in there. A whole new application for go pro
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Autocross/Hillclimbs
2x 1984 944 N/A; 1988 951S Silver Rose; 81 VW Rabbit Diesel; MK4 VW R32
President - Bridge City Autosports http://www.bcautosports.club |
Well, you don't want to use water to put it out....
JR |
Bollweevil
In 1971 VW had a large regional distribution center in San Antonio just off IH35. A electrical short started a fire which quickly got out of control. The SA fire department was called, however the VW warehouse was actually about 1/4 mile or so outside the SA city limits so by city policy and lacking any kind of agreement the SA fire trucks pulled up the city limit signs and stopped. The volunteer fire department which actually served that area was called but by the time they got there they could do nothing due to the size of the fire (and with lots of magnesium burning) so they pretty much watched the entire structure and all it's contents burn to the ground. Needless to say VWofA told SA not only no but hell no when asked if they would be rebuilding the distribution center in SA. SA shortly amended it's policy about the SA fire department not going beyond the city limits to help with large fires. I don't remember where VW moved the distribution center to?
Jack 74 911 Coupe 2.7L - K21 Option - S suspension Last edited by 74-911; 12-25-2015 at 08:10 AM.. |
I once had some dealings with the Fire Marshall in San Antonio and I can say he was one of the biggest idiots I ever met. No idea if he's still there, but a city of that size deserved a lot better than he gave.
JR |
Pretty sure plastic and related technology will progress faster than Mg alloys.
Sherwood |
Navin Johnson
Plastic is so 1980s...
I remember seeing this car at Lime Rock trying to dice with the Porsche 956/962 Basically a Ford Cosworth made out of plastic "Torlon" in a Lola chassis, This was when Porsche, Jaguar, Datsun, Aston-Martin had some serious weaponry...... as usual Porsche had the staying power... Plastic engine There is a company making a go at a plastic engine again.... Polimotor 2 Just noticed the backer designer of the new engine is the guy behind the original one
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 12-29-2015 at 04:04 PM.. Reason: noted something |
My daily driver has a magnesium block.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
