Which is why the ampere turns using an "I" results in less magnetic field strength than an "E & I" core.
An inductor (or a flyback transformer) will typically have an air gap where a transformer will not. What point are you trying to make?
Rick 88 Cab |
Never said anything about eddy current loses. Eddy current loses result from the molecular structure of the core material and induced current flow in that material. The subject matter regards the amount of magnetic flux vs ampere turns. Example: 1 ampere turn with an "I" core transformer or inductor will be produce "N" levels of magnetic flux, whereas 1 ampere turn in an "E & I" core transformer or inductor will produce "N" * X levels. In the linked document X = 1.6 Last edited by wwest; 01-11-2016 at 06:37 PM.. |
This is all very interesting but what is the answer to the ORIGINAL question?
Can I safely use a MSD Blaster coil?
There is no data on any of them so it is just an opinion.
But what fun is that when you can rewrite scientific laws?
Rick 88 Cab |
I think when you get by all the dick swinging the answer is yes.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Discovered that cooling the CDI box, garden hose water spray, would result in the car starting back up right away. Your CDI box may be overheating, or the MSD blaster. The latter becomes more probable if you non-resistor wiring and/or sparkplugs. |
CDI coil values are indicated and linked to in post #29. Maybe helpful in choosing a replacement CDI coil.
Dave |
Rick 88 Cab |
Page 48, figure 34, Bosch GT40 cannister coil, 17mj.
Page 49, figure 35, Bosch GT40T transformer "coil", 28mj
