wwest's Avatar
Originally Posted by rick-l View Post
That "I" core has a pretty big air gap
Which is why the ampere turns using an "I" results in less magnetic field strength than an "E & I" core.
Old 01-11-2016, 03:11 PM
An inductor (or a flyback transformer) will typically have an air gap where a transformer will not. What point are you trying to make?
Rick
88 Cab
Old 01-11-2016, 04:10 PM
wwest's Avatar
That would be great if any of the systems discussed here had a Royer oscillator. All the systems discussed here have a flyback. The energy is returned to the battery.
Where are the 60% losses due to eddy currents you discuss?
Never said anything about eddy current loses.
Eddy current loses result from the molecular structure of the core material and induced current flow in that material.
The subject matter regards the amount of magnetic flux vs ampere turns.
Example: 1 ampere turn with an "I" core transformer or inductor will be produce "N" levels of magnetic flux, whereas 1 ampere turn in an "E & I" core transformer or inductor will produce "N" * X levels.
In the linked document X = 1.6
Old 01-11-2016, 05:34 PM
HarryD's Avatar
This is all very interesting but what is the answer to the ORIGINAL question?
Can I safely use a MSD Blaster coil?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-11-2016, 05:52 PM
Yeah, what he said!
Old 01-11-2016, 06:44 PM
There is no data on any of them so it is just an opinion.
But what fun is that when you can rewrite scientific laws?
Rick
88 Cab
Old 01-11-2016, 07:11 PM
theiceman's Avatar
I think when you get by all the dick swinging the answer is yes.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
wwest's Avatar
Originally Posted by Sunroof View Post
My car has been known to suddenly die after a long run on the road and I thought it might be fuel related. Lately though someone suggested that the MSD Blaster ignition coil I installed might be overheating and causing the shutdown after a nice run with the car. The questions came up as to whether I was using a non-resistor rotor? does the Blaster has an internal resistor? or I have external ballast resistor?
I do use the 6500 rpm cut off rotor, which I just realized is not the "non resistor rotor". I will switch to the non resistor rotor, but can anyone shed any light on what's going on with this system set up. And yes, I have bought the silver made in Brazil coil, which failed me miserably after purchase.
thanks
Bob
1973.5T
Post having the tach jumping, over-voltage episode, new alternator installed, my '78 acted as you say. Engine shut-down randomly after a period of running flawlessly.
Discovered that cooling the CDI box, garden hose water spray, would result in the car starting back up right away. Your CDI box may be overheating, or the MSD blaster. The latter becomes more probable if you non-resistor wiring and/or sparkplugs.
Old 01-11-2016, 07:54 PM
Found this old thread (911 SC no start Perma Tune question) where various
CDI coil values are indicated and linked to in post #29. Maybe helpful in choosing
a replacement CDI coil.
Dave
Old 01-11-2016, 08:26 PM
"I" core: That 60% energy level loss due to magnetic field "leakage" will be dissipated as HEAT with in the coil structure.
(Page 48)
http://www.worldphaco.net/uploads/CAPACITIVE_DISCHARGE_IGNITION_vs_MAGNETIC_DISCHARG E_IGNITION..pdf
I have no idea where you got the 60% number from that article. The referenced refers to 16% or 28% efficiency transferring energy from the capacitor to the inductor which was derived on page 42. If the core heats up it is due to the resistance of the windings not leakage inductance.
Rick
88 Cab
Old 01-12-2016, 08:07 AM
wwest's Avatar
Page 48, figure 34, Bosch GT40 cannister coil, 17mj.
Page 49, figure 35, Bosch GT40T transformer "coil", 28mj
Old 01-12-2016, 10:22 AM
