3rd_gear_Ted's Avatar
Originally Posted by Mahler9th View Post
I think that one of the best ways to address small angle throttle response/pedal travel issues is the change the geometry. One of my friends (who built my car and builds my engines) suggested this t me years ago. In my case, the change was made on the lever on the transmission pivot. I lengthened it quite a bit.
My friend has done this mod to a few cars.
Very easy to do.
I don't think the conversion to a cable set up changes geometry by itself.
This is what I had to do to get full throw of the throttle plate, but most importantly in the added throw is definite actuation of the WOT micro switch that provides full throttle mapping to the fuel injectors. Now my S. Wong chip and my 3.6 works like advertised.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 05-28-2017, 03:54 PM
In this image, you can see my okiefication of the linkage:
Hey! I'm an Okie.
Old 05-28-2017, 04:04 PM
So what modifications are needed to the 964 cable to make it work with an SC pedal?
Old 05-28-2017, 08:40 PM
arrivederci's Avatar
I had the bicycle cable with the lengthened arm at the trans pivot. I thought it felt terrible so I found a thread on the 964 cable mods. I don't remember what exactly I had to change. It involved some copper fitting from the hardware store and removing part of the cable housing (which was a pain). Works awesome now!
- '72 911T
- '81 911SC Euro
Old 05-29-2017, 09:30 AM
faverymi's Avatar
I have no cable system. It was terrible.
SC accelerator console that mounts perfectly in the 964 cruise control location.
From there a modified in lenght accelator rod that attaches to TB butterfly.
Voila. Perfection. No drag no issues. Just right
Old 05-29-2017, 01:56 PM
Here ya go...scroll down in this thread.
How To Convert Throttle Linkage on 3.6 Transplants?
- '72 911T
- '81 911SC Euro
Old 05-29-2017, 04:02 PM
froggert's Avatar
I have the Patrick cable. It's super smooth, but pedal travel is really long. I wish there was a way to easily shorten it.
Old 05-31-2017, 07:46 AM
Thanks for the info guys! I think I am going to go ahead and fabricate my own from the bellcrank back. I want to get a little quicker initial opening, so I will play with the motion ratios a bit.
Mike
Old 06-01-2017, 07:39 PM
Thanks for the help and info. I made a new throttle cable and bell crank with better motion ratios. (Lokar 36" throttle cable kit).
The difference is huge. Much better throttle response and easier to match the downshifts. One of the best mods I have done. Strongly recommend it!
Mike
Old 06-18-2017, 09:23 PM
