Chain fence eating turbo
Sounds like a good read
Sal, since the 3.4 build is popular, are there off-the-shelf cam grinds that have the target LSA of 112?
My head just exploded.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
DC Cams has a few as does Elgin and WebCam. Plus some factory cams, like the 964 cam that does well in these 3.4L engines. If you think about moving a 3.2L to 3.4 or 3.5 and twin plugging it you are basically creating a 964 type motor so why not use the 964 cam? The 964 factory cam has the intake on about 115deg and the exh on 111deg centerlines. average of about 113.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
What you said here is correct but the real reason is simply because if you increase the LSA and don't touch the duration you simply caused the intake valve to close later and thus reduced dynamic compression. But you can easily fix the dynamic compression issue by increasing the static. The inverse is true if you shorten the LSA, here you increased overlap and close the intake sooner and the dyn comp goes up.
You can NOT and SHOULD NOT alter the intake valve close point without revisiting the dynamic compression calculations! This is why you can't just throw any cam into a motor. The very best engine designers start with the cam and the head design and flow numbers and build the motor around it not the other way around. So while your statements below are correct they are not the entire story, hopefully my explanation helps. Quote:
