Need help interpreting leak down sound
I did a leak down test on my engine, and while three of the cylinders were solid (2-5% leakage), I got three others with 15-25% leakage. The bad cylinders were 2, 4, & 5, so one on the left side of engine and two on the right side. For all three of these bad cylinders I heard kind of a pulsing, gurgling sound coming from the upper, LEFT side of the engine. Hard to make out but close to the top valve covers on the left side. No significant sound from anywhere else. What could this mean?
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... Last edited by jwakil; 01-20-2016 at 09:17 PM.. |
JW... typically one listens to the exhaust pipe (for leaking exhaust valves), intake (for leaking intake valves), and case breather (for leaking rings.) A pulse and gurgle... that sounds organic!
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
I don't think pulse/gurgle is significant, the point is the sound is coming from one place, which is near the top left of the engine, near top valve covers but below the intake manifold. I wasn't sure exactly where in intake valve leak would be heard.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
RETIRED
Have you checked the head studs?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Head studs were recently replaced as part of a top end rebuild. What part of the intake would one listen to for leaking intake valves? I haven't adjusted the valves since the rebuild and thinking I might have valve leakage but don't know where the air would escape if the throttle is closed?
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... Last edited by jwakil; 01-21-2016 at 11:33 AM.. |
Home of the Whopper
Intake valve can be heard through the intake, try near the air cleaner.
Exhaust valve through the exhaust, put your ear at the muffler tail pipe. Rings through the oil fill. Head studs usually through the alt fan.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
If this was just done, did you rering it and hone the cylinders or replace them? You should re-torque the head studs and adjust the valves too, then check the leak down again. |
I could have sworn Wayne's 101 book said leak down should be done on a cold engine but maybe that was for the valve adjustment. I'll look again. The logic is that the clearance specs are set for cold, not hot.
You have 3 good and 3 no so good, you have a problem. Hot or cold you should have similar readings across the board.
disband
since 911's don't have wings id consider that the tried & true method of leakdown with a cold motor should be the choice. I realize a hot motor should make for higher numbers due to components expanding, but those may be skewed if previous efforts were done cold.
im not an aircraft mechanic, or a Porsche mechanic, but do spend a bunch of time a local shops as I have no life.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Air Medal or two
There is a big difference between hot and cold.
I like it hot. Next- drive it around the block and try it again. Make sure you are at TDC or close as possible An AC engine only ask about 1/2 HP per a cubic inch. ( Way derated ) Plus - They are loose and wore out day one by auto standards.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Platinum Member
However, if the leak-down test is performed on an engine that isn’t warmed up, then the test may not give accurate results. Tech Article by Wayne: Pelican Technical Article: Time to Rebuild? - Part II |
Banned
Like Mr. Boom noted, a leak down test on a cold engine is an inaccurate way to measure cylinder pressure loss regardless of the vehicle the engine operates in. You can get a wildassed guess measurement that way, but if something doesn't seem right, then the next thing you do is repeat the test warm, so might as well do it correctly in the first place.
disband
I may have only made it partially clear that however you set your baseline numbers, cold, warm or smoking hot that commits you to that method moving forward. if you base a healthy motor on a warm reading it should be stated as to how warm. most shops do it cold so they do not have to burn knuckles or explain where exactly the number are derived. a cold motor may not tell you what you want to hear, but it's a good, solid basis to set an even playing field, without numbers skewed by a warm, hot, or somewhere in between motor when tested.
You have this backwards. If you want skewed numbers, start with a cold engine. Then, progressively warm the engine to get less skewed numbers. The least skewed and most predictive will be those test results when the engine is at operating temp.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
My bad, after going back to my references I realize the cold engine requirement is for valve adjustment, not the leak down test. I will go back and redo the leak down on a warm engine and see what happens.
