Common sockets, allen keys, nuts, bolts, screws and hardware kits.
So I was doing a search for some common metric nuts/bolts/screws/washers and such for my car in hopes that I could buy in bulk and not have to worry about matching and finding specific replacement hardware during my build.
In my research I did come up with some common socket and allen Key sizes FYI. I was also reading on the pros and cons of cad coated mild steel vs stainless (soft and galling) and even titanium (cost, some gall... match with steel nut). I know a guy that replaced every nut and bolt in his car with titanium, so I am going to see if he still has a purchase list for hardware, and share it here if he still does. Feel free to add (correct) to the list. I can add to this original post for the benefit of others. wrench/Socket sizes: 36mm - axle and flywheel nuts 36mm or 34 or 32??? - hard oil lines 27MM – steering wheel 24mm - ? fan pulley 22mm (87' car)- shock bolt 22mm - reverse switch and brake light switches (reverse offset wrench) 19mm deep socket – wheel lugs 8,10,13,15,17 - nuts and bolts 11mm 9, 14 (?) - for brakes and lines 9mm, 7mm - brake bleeders Allen Keys: 3 mm - to adjust CIS enrichment 4 mm - shifter swivel 5 mm - 6 mm cap bolts on sheet metal and rocker shafts 6mm - 8mm - 10mm - head nuts 12 or 13 mm? - rear toe adjusters 17mm - Bolts/Nuts/screws M14x 1.5mm - wheel studs (Titanium, custom made for a local Pelican's electric 88' 911 drag racer) M12x1.5mm M10x1.5mm M8x1.25mm M6x1.0mm Complete case hardware super kit (PEL-REBKT-06) M6 Nylon Self-Locking Nuts M8 Nylon Self-Locking Nuts M8 Oval Self-Locking Nuts M8 Spring Washers M6 Aluminum Washers M8 Aluminum Washers Varoius hardware kits (screws, nuts, bolts, etc) http://www.*************/911-1974-1989/hardware-sets.html Replace asterisks with stoddard dot com Note you can select different years of cars. Interior screw set Interior Screw Set For Porsche Automobiles
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 02-10-2016 at 03:22 PM.. |
3 mm Allen to adjust CIS enrichment
4 mm Allen for shifter swivel 5 mm Allen for 6 mm cap bolts on sheet metal and rocker shafts 10mm Allen for head nuts So you need a whole set Bruce |
12 or 13 mm Allen socket for rear toe adjusters.
The spark plug socket, one from the tool kit preferred.
BTW Shocks bottoms are 22mm on the 87 Also need smalller than 36 mm to do the oil lines, counter wrench. 34 or 32 11mm 9, 14 (?) flare for brakes and lines
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
Undocumented User
There are some things (reverse switch and brake light switches) that are an absolute bitch without a 22mm offset wrench.
TAG you're right about that 22mm offset Hazet
AND the 36 mm socket for the rear axle better be 3/4 drive
Oil drain plug wrench. Forgot the size.
Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
9&7mm For brake bleeders
Ernie |
special balll joint tool socket
valve adjuster tool wrenches for tubing fittings. 12"x12" square, 2 x 4 to drop fan housing to remove alternator. cam timing fixtures and dial indicators are nice to have. harbor freight wheel bearing tool for removing/installing wheel bearings. various torque wrenches. A 3/4" that goes to 300# for wheel bearings. i heated and bent a 13mm wrench and added a handle to be able to loosen/tighten the distributor nut. Cam nut socket and special socket. small welder is nice.
1975 911S Targa Silver Anniversary Edition |
Fleabit peanut monkey
8MM triple square bit needed for adjusting the door striker plate (if that's what you call it). You can buy a set of four or five different sizes for cheap at the right auto parts store.
Open the door and look at the door latch receiver on the door frame. 12 point female "allen" bolts. 12 point = triple square name.
1981 911SC Targa Last edited by Bob Kontak; 01-24-2016 at 08:00 PM.. |
That rear axle nut socket has to be 3/4" drive. You'll snap a 1/2" drive, ask me how I know.
allen keys should be high quality steel, such as Lisle or Snap On. I use my Craftsman punch set. Do not buy inferior quality steel punches. I also have the set of Lisle press tools to install bearing races. Very handy. An LM-1 is to die for. And I also bought the very spendy Sir Tools rear wheel bearing tool. I can do that job from start to finish in about an hour now. |
The el-cheapo's will work because the load is small on the striker plate bolts. If you get into CV axles on a VW, don't skimp on these tools or you will regret it.
1981 911SC Targa |
This thread has some links to hardware kits, including an interior screw kit. Very useful...
Sources for hardware kits?
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
