gliding_serpent's Avatar
Common sockets, allen keys, nuts, bolts, screws and hardware kits.
So I was doing a search for some common metric nuts/bolts/screws/washers and such for my car in hopes that I could buy in bulk and not have to worry about matching and finding specific replacement hardware during my build.
In my research I did come up with some common socket and allen Key sizes FYI. I was also reading on the pros and cons of cad coated mild steel vs stainless (soft and galling) and even titanium (cost, some gall... match with steel nut). I know a guy that replaced every nut and bolt in his car with titanium, so I am going to see if he still has a purchase list for hardware, and share it here if he still does.
Feel free to add (correct) to the list. I can add to this original post for the benefit of others.
wrench/Socket sizes:
36mm - axle and flywheel nuts
36mm or 34 or 32??? - hard oil lines
27MM – steering wheel
24mm - ? fan pulley
22mm (87' car)- shock bolt
22mm - reverse switch and brake light switches (reverse offset wrench)
19mm deep socket – wheel lugs
8,10,13,15,17 - nuts and bolts
11mm 9, 14 (?) - for brakes and lines
9mm, 7mm - brake bleeders
Allen Keys:
3 mm - to adjust CIS enrichment
4 mm - shifter swivel
5 mm - 6 mm cap bolts on sheet metal and rocker shafts
6mm -
8mm -
10mm - head nuts
12 or 13 mm? - rear toe adjusters
17mm -
Bolts/Nuts/screws
M14x 1.5mm - wheel studs (Titanium, custom made for a local Pelican's electric 88' 911 drag racer)
M12x1.5mm
M10x1.5mm
M8x1.25mm
M6x1.0mm
Complete case hardware super kit (PEL-REBKT-06)
M6 Nylon Self-Locking Nuts
M8 Nylon Self-Locking Nuts
M8 Oval Self-Locking Nuts
M8 Spring Washers
M6 Aluminum Washers
M8 Aluminum Washers
Varoius hardware kits (screws, nuts, bolts, etc)
http://www.*************/911-1974-1989/hardware-sets.html
Replace asterisks with stoddard dot com
Note you can select different years of cars.
Interior screw set
Interior Screw Set For Porsche Automobiles
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 01-24-2016, 03:57 PM
3 mm Allen to adjust CIS enrichment
4 mm Allen for shifter swivel
5 mm Allen for 6 mm cap bolts on sheet metal and rocker shafts
10mm Allen for head nuts
So you need a whole set
Bruce
Old 01-24-2016, 04:27 PM
gtihop's Avatar
12 or 13 mm Allen socket for rear toe adjusters.
Old 01-24-2016, 04:31 PM
ganun's Avatar
The spark plug socket, one from the tool kit preferred.
BTW Shocks bottoms are 22mm on the 87
Also need smalller than 36 mm to do the oil lines, counter wrench. 34 or 32
11mm 9, 14 (?) flare for brakes and lines
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 01-24-2016, 04:59 PM
Undocumented User
McLaren-TAG's Avatar
There are some things (reverse switch and brake light switches) that are an absolute bitch without a 22mm offset wrench.
Old 01-24-2016, 05:09 PM
ganun's Avatar
TAG you're right about that 22mm offset Hazet
AND the 36 mm socket for the rear axle better be 3/4 drive
Old 01-24-2016, 05:19 PM
Oil drain plug wrench. Forgot the size.
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 01-24-2016, 05:27 PM
emac's Avatar
9&7mm For brake bleeders
Ernie
Old 01-24-2016, 05:58 PM
47silver's Avatar
special balll joint tool socket
valve adjuster tool
wrenches for tubing fittings.
12"x12" square, 2 x 4 to drop fan housing to remove alternator.
cam timing fixtures and dial indicators are nice to have.
harbor freight wheel bearing tool for removing/installing wheel bearings.
various torque wrenches. A 3/4" that goes to 300# for wheel bearings.
i heated and bent a 13mm wrench and added a handle to be able to loosen/tighten the distributor nut.
Cam nut socket and special socket.
small welder is nice.
1975 911S Targa
Silver Anniversary Edition
Old 01-24-2016, 07:43 PM
Fleabit peanut monkey
Bob Kontak's Avatar
8MM triple square bit needed for adjusting the door striker plate (if that's what you call it). You can buy a set of four or five different sizes for cheap at the right auto parts store.
Open the door and look at the door latch receiver on the door frame. 12 point female "allen" bolts. 12 point = triple square name.
1981 911SC Targa
Old 01-24-2016, 07:51 PM
That rear axle nut socket has to be 3/4" drive. You'll snap a 1/2" drive, ask me how I know.
allen keys should be high quality steel, such as Lisle or Snap On. I use my Craftsman punch set. Do not buy inferior quality steel punches.
I also have the set of Lisle press tools to install bearing races. Very handy.
An LM-1 is to die for. And I also bought the very spendy Sir Tools rear wheel bearing tool. I can do that job from start to finish in about an hour now.
Old 01-24-2016, 07:53 PM
Bob Kontak's Avatar
Agree. The triple square bits I mentioned may also be purchased from NAPA. They are K-D brand and about $8 per bit.
The el-cheapo's will work because the load is small on the striker plate bolts. If you get into CV axles on a VW, don't skimp on these tools or you will regret it.
1981 911SC Targa
Old 01-24-2016, 08:05 PM
This thread has some links to hardware kits, including an interior screw kit. Very useful...
Sources for hardware kits?
1973 BMW 2002Tii
2016 Ford Focus RS
Old 02-10-2016, 02:15 PM
